 Post subject: Hitachi HDT7210SLA corrupted NV-RAM
PostPosted: September 25th, 2011, 3:55
The patient is Hitachi HDT721010SLA360 which spins but is not recognized on PC3000. After swapping NV-RAM to a fine pcb the behaviour remains same. Any hints how to check the validity of the patient's NV-RAM and how to read its' content?
 Post subject: Re: Hitachi HDT7210SLA corrupted NV-RAM
PostPosted: September 25th, 2011, 4:02
why swapping NV to new pcb?
how did you know its PCB issue?
and does it click when you power it on?
PostPosted: September 25th, 2011, 4:24
I could not read the content of the NV-RAM of the patient. So I had no other choice (to my knowledge).
It does not exactly click it's just trying to read and then stops spinning.
PostPosted: September 25th, 2011, 4:52
Power it up in ur 3k
and select the family and see if it reads it
those Hitachi hdd`s are tricky
PostPosted: September 25th, 2011, 5:06
That's what I've been doing since the NV-RAM swap. PC3K is not recognising the drive. The drive is a kind of trying to read initiative data but after couple of seconds it stops spinning. No clicking no other wierd sounds either. I'm out of ideas.
PostPosted: September 25th, 2011, 8:16
Sent PM
PostPosted: September 27th, 2011, 16:23
I've got almost the same problem so if you have a solution. PM me!
PostPosted: September 27th, 2011, 20:51
Almost? Can you clarify?
And what tools do you have exactly?
PostPosted: September 28th, 2011, 6:09
Place donor PCB with non-native ROM. Maybe you get SA access. If not, then adjust SA top values (or use NV-RAM Adjustment feature) till you can reach SA. Then read NVRC module.
If NVRC is bad, search in RAM for native NVRC copy.
Users browsing this forum: Google [Bot], Ricardo Arnoud and 274 guests
