 Post subject: WD5000BEVT-00A0RT0 LDR file needed
PostPosted: October 8th, 2011, 18:19
ROM:
ROM reading............................. : Ok
ROM Data size........................... : 256 Kb
ROM version............................. : 13.CBH
ROM generation.......................... : 13.CBH
Link table version...................... : 05.C9.
Consolidated ROM version................ : 001300CB
ROM Modules:
Flash ROM dir reading................... : Ok
Modules directory address............... : FIXED
Heads configuration..................... : by map
Heads number............................ : 4
Heads number in use..................... : 4
Switched off heads...................... : No
Heads map............................... : 0,1,2,3
ROM Firmware version.................... : 001300CB
Can anyone have?
 Post subject: Re: WD5000BEVT-00A0RT0 LDR file needed
PostPosted: October 9th, 2011, 6:59
should work
WDC WD5000BEVT-00A0RT0 01.01A01 WD-WX51A3062117 Module 11.zip [176.56 KiB]
Downloaded 826 times
Zero Alpha: zeroalpha.com.au
PostPosted: October 10th, 2011, 8:10
Thank you but firmware version is: 001400DH - look at the header. Unfortunately it don't work.
PostPosted: October 10th, 2011, 11:28
Looked, but afraid I don't have this version :-(
What date is your HDD?
PostPosted: October 11th, 2011, 3:33
Date is 19 NOV 2009.
PostPosted: October 11th, 2011, 4:14
Closest I have is 001300CC :(
PostPosted: October 11th, 2011, 9:34
Same
PostPosted: October 17th, 2011, 13:30
Hello!
Here you have one of 640Gb. I send all firmware. I hope it will work!
Best Regards!
PostPosted: October 17th, 2011, 13:32
Hello!
Best Regards!
WDC WD6400BEVT-22A0RT0 01.01A01 WD-WX30AB9H9570.rar [7.32 MiB]
Downloaded 487 times
PostPosted: June 2nd, 2012, 5:25
i need to ROM version............................. : 13.CCG,the hddguy have a same firmware ,can you send all firmware to me ?
Can anyone have?
Thank you!
