1 TB ST91000430AS(external removed from casing) Problem:while using disk cable unplugged,replgged cable after that not detecting. My finding: detects model number s/n without capacity after some time in PC3kPortable. if detected then it give me 2 warnings hdd locked,translation violation. if im doing HDD Lock (LED: 000000CC soln giving error drive not ready. and continus knknkn low sound Tech Key... Drive not ready DiagError 00005014 F3 2> Test : Solution for problem "HDD Lock (LED: 000000CC)" HDD power supply switching OFF/ON... Spin Up... Drive not ready
Tech Key... ExecuteSpinRequestably HDD have "HDD Lock (LED: 000000CC)" problem FAIL Op=0100 Resp=0003on for problem "HDD Lock (LED: 000000CC)" FAIL Op=0100 Resp=0003utions FAIL Op=0100 Resp=0003 FAIL Op=0100 Resp=0003 FAIL Op=0100 Resp=0003HDD have "Translatioin violation (0 GB)" problem FAIL Op=0100 Resp=0003on for problem "Translation violation (0 GB)" FAIL Op=0100 Resp=0003utions FAIL Op=0100 Resp=0003 FAIL Op=0100 Resp=0003 FAIL Op=0100 Resp=0003 FAIL Op=0100 Resp=0003 DiagError 00006008 r problem "HDD Lock (LED: 000000CC)" Spin Errorsupply switching OFF/ON... Elapsed Time 5.482 secs R/W Status 2 R/W Error 84150180 F3 2> Drive not ready
if not detected error FAIL Op=0100 Resp=0003
| Attachments: |
