 Post subject: Read_long
PostPosted: October 17th, 2011, 20:24
Does anyone know of a tool that sends a read_long command to a drive? Or the c code that would do that?
 Post subject: Re: Read_long
PostPosted: October 17th, 2011, 20:48
What are you trying to achieve?
www.datarecoveryne.com
PostPosted: October 17th, 2011, 20:54
read long is an obsolete command.
PostPosted: October 17th, 2011, 21:40
I know read long is an obsolete command. I need to recover data from a sector that was made bad with a write long.
PostPosted: October 18th, 2011, 10:26
@Cowtippa: There's no information volunteered so far about the h/w & s/w being used (are you deliberately trying not to give away much info?), but here are a few general comments to address those very general questions...
I used my own code in the past, so I don't have a recommendation for a tool. If you're looking for one, I suggest you investigate MHDD and its scripting (if your HBA is supported).
Your answer depends on your chosen OS (and often the specific version of that OS), and the relevant ioctls which it supports - and in some cases, also varies with the HBA being used. If you're stuck for ideas, you might want to look at the work done in the smartmontools code, as they show some related techniques for different OS.
Users browsing this forum: No registered users and 70 guests
