 Post subject: WD RAPTOR WD800ADFS-75SLR2 SA PROBLEM
PostPosted: October 20th, 2011, 4:59
Hi Guys,
I got a WD RAPTOR WD800ADFS-75SLR2 that in the begining have modules damaged in copy 0 and in the initial log on the PC3000 in the family when he read the SA have a Translator problem.
Modules damaged in copy 0:
44 glist "A"
25 rbblist Translator "A"
2E dfpdata SMART parameters table "B"
14 mrdvt "B"
29 drmlog SMART "c"
2D drmalter SMART "C"
21 eventlog "B"
FA Selfscan test microprogram "Dr"
I backup all the modules (copy 0 and 1) and the copy 1 all the modules here good.
I write the copy 1 for 0 and he give's me the log "ok", and when i turn off/on and try to detect the family he give's me an error on the techno key.
So now its worst, i can't be in the utility and work in SA.
Any one knows what is the problem our have seen something like this?
Best Regards,
Data Recovery Technician - If Data is important don't DIY without knowing the real problem.
 Post subject: Re: WD RAPTOR WD800ADFS-75SLR2 SA PROBLEM
PostPosted: October 20th, 2011, 11:16
Most likely heads.
www.datarecoveryne.com
PostPosted: October 20th, 2011, 11:28
"Most likely heads."
Hi harddrivespecialist, i forgot to menction that in the begining i don't have acess to sectors, i thoght because the drive became with factory password. I clear the pass but was the same. then i make the steps in the first post.
I don't hear any noise when the drive spins and try to read the SA.
First of all, try to clean the heads?
Thanks for the reply.
PostPosted: October 20th, 2011, 11:35
I don't think cleaning will help you.
What are you trying to achive? You need data or working drive?
PostPosted: October 20th, 2011, 11:41
I need to recover the data.
PostPosted: October 20th, 2011, 11:58
You have to use different approach.
If you have advanced DR tools, I would suggest to read a manual.
PostPosted: October 21st, 2011, 5:53
So now i can't acess the SA in safe mode, he give me this error:
http://www.megaupload.com/?d=1LN3E75E
If anyone could ever help i was gratefully.
PostPosted: October 21st, 2011, 17:31
Well, if translator is bad, then no access to user data.
Although not always reliable, have you tried running a "heads test" in the utility?
PostPosted: November 18th, 2011, 12:35
This case i change the Heads and i can read the SA, and make an image a 100%
Data recovered sucessfull. :)
Users browsing this forum: Google [Bot] and 311 guests
