 Post subject: Disable ECC?
PostPosted: November 8th, 2005, 22:16
Can ECC be disabled on a hard drive to speed reading of data? I realize the data may be bad, but I will figure that out myself after making an image. It just takes soooo long to copy a drive with lots of ECC errors. If possible, what is the best way to do this? Can I do it through SMART commands? Private mail here is fine if you don't want to tell the world.
 Post subject:
PostPosted: November 9th, 2005, 2:04
U can use Read long ATA command.
 Post subject:
PostPosted: November 9th, 2005, 9:56
JFYI: Read Long - uses PIO mode 0, 1 sector at call transfer - most slowest way to read data. Also if you don't use ECC each read can give different data :wink:
best regards, vi http://www.scspb.ru/pchdd/ http://pchdd.narod.ru
 Post subject:
PostPosted: November 9th, 2005, 14:48
Maybe just limit the ECC retries , if you have the power :)
A man is as old as he feels, and a woman as old as she looks
 Post subject:
PostPosted: November 9th, 2005, 20:12
Probably why they called it "read long." :-)
Users browsing this forum: Google [Bot] and 421 guests
