 Post subject: Seagate 7200.11 750Gb bsy (not fixed with the usual way)
PostPosted: October 31st, 2011, 14:58
Hi everyone
i have 2 7200.11 drives. 750Gb and 1Tb. it seems to have the bsy problem. tried to fix the bug via Atola terminal but i get the same error during the proccess and it is stuck there
F3 T>/2
F3 2>Z
LED:000000CE FAddr:00280569
any suggestions?
thank you in advance.
 Post subject: Re: Seagate 7200.11 750Gb bsy (not fixed with the usual way)
PostPosted: October 31st, 2011, 16:04
What firmwares are they?
PostPosted: November 1st, 2011, 4:05
Both of the drives are F/W: SD15
thank you
PostPosted: November 1st, 2011, 5:59
I think you are trying to send commands with HDA attached. You isolate PCB from HDA?
F/W: SD15
some how seems easy to fix
but need to know what 2 do
PostPosted: November 1st, 2011, 9:22
I think you are sending commands way too fast.
Patience is a virtue.. ;-)
PostPosted: November 1st, 2011, 13:52
:D
PostPosted: November 2nd, 2011, 8:09
it finally worked. i changed the power supply that connected the HDD to the Atola and worked fine.
i agree, and day by day i note that data recovery needs a lot of it :) . thank you for your concern in my queries.
PostPosted: November 2nd, 2011, 17:25
I would have said you weren't allowing enough time for the PCB to come DRDY before issuing the "Z" command. Sometimes they do take a while.
PostPosted: November 3rd, 2011, 5:50
My point exactly.
PostPosted: November 3rd, 2011, 17:33
northwind wrote:
My point exactly.
:D
Users browsing this forum: jimmydata, nicola and 130 guests
