 Post subject: Burnt out component on Samsung HM160JC P.C.B.
PostPosted: October 22nd, 2011, 5:28
Hi all,
on PCB diagnosis, you can see there is a burnt out coil very clear. The Marvell IC seems to be affected as well (see images). I can't see any external EEPROM in PCB, so I may assume that Marvell's IC has internal EEPROM.
I have to orther a donor PCB, but before I do, I would like to know if in case the Marvell IC it's really damaged, is possible to get data from HD without programing EEPROM on this Samsung's har drive?
Thanks.
Alex.
File comment: M60 Rev1 Samsung PCB
File comment: Burnt coil
File comment: Marvell IC damaged
 Post subject: Re: Burnt out component on Samsung HM160JC P.C.B.
PostPosted: October 22nd, 2011, 6:21
Hi you can use another M60 pcb, there should not be any unique parameters on those pcb's.
Regards/ Bosse
http://www.rescue-it.se
PostPosted: November 3rd, 2011, 8:11
Thanks mr spokk.
I've allready ordered a donor pcb.
Will post the results as soon as I try replacement.
Alex.
Users browsing this forum: No registered users and 87 guests
