 Post subject: Hard Disk data recovery help
PostPosted: November 3rd, 2011, 4:30
I am owning a Samsung 7200 rpm, 320GB hard disk and its not showing up in the bios after the power failure. I identified the damage in its board, so changed the board with another similar board and then identified that the platters inside the hard drive have pasted or locked together. The lock doesn't seems to get released even though the hard disk starts on after changing the board and again the hard drive is not showing up in the bios. Please advice me on how i am gonna release the platters, is it OK if i release it manually with my hand or is there any other alternative methods to recover data?
 Post subject: Re: Hard Disk data recovery help
PostPosted: November 3rd, 2011, 6:02
How exactly did you identify that the platters are stuck?
What exactly do you mean that the drive starts after you changed the board?
To put it simply, if you're inexperienced with DR and platters are stuck and you try to move them yourself, it is game over. If you care about data, you can do DIY, but you have to accept the consequences too.
PS. I don't know about others but i would appreciate if you don't use red color on your post. Thanks.
PostPosted: November 3rd, 2011, 6:26
The platters are not stucked, but I notice that there are no gap between each platter, it means that all the platters are pasted to each other. When I insert the new board, I heard a clicking sound inside the Hard drive which made me to think that the board suits my HDD.
PostPosted: November 3rd, 2011, 6:28
I mean no offense, but you do not have any ideas about what you are doing and if data is important there is realisticalyl one option - send to a professional and hope your repair attempts has not made things worse.
PostPosted: November 3rd, 2011, 8:17
I'll try a professional, because the data is worth spending.... Thanks for your advice
Users browsing this forum: nicola and 78 guests
