 Post subject: Seagate ST3500413AS 500 GB showing 3.9 GB and not detecting
PostPosted: November 2nd, 2011, 5:29
Seagate 500 GB HDD 3.5 inch showing 3.9 GB and not detecting, can hear clicking sound 11 times and stops and shows 3.9 GB in hard disk sentinel software and not able to access the HDD.I also have a same HDD like that in spare,What could be the problem.
It also shows model number ST_M13FQBL .
 Post subject: Re: Seagate ST3500413AS 500 GB showing 3.9 GB and not detect
PostPosted: November 2nd, 2011, 5:37
It shows ID of ST_M13FQBL also?
Problem is likely physical if you can hear clicking sounds. I guess after clicking stops HDD motor powers off too?
Firstly, proper diagnosis is needed to determine the exact problem. If physical repairs are needed, you should consult a professional. these are not 'easy' disks to work on and having a spare does not mean you have a suitable donor. There are factors such as heads compatibility that should be considered
PostPosted: November 2nd, 2011, 9:13
Could it be also the problem of head that its not detecting the track 0 and sends a signal not detecting and stops the motor spinning(the motor also stops spinning after 11 clicks )
PostPosted: November 4th, 2011, 12:33
I successfully replaced the heads and the 11 clicks have gone but still its showing 3.9 GB and showing ID model ST_M13FQBL need help now :cry:
PostPosted: November 4th, 2011, 12:45
Does it spin?
Have you done a head test?
PostPosted: November 4th, 2011, 12:50
SA is not read. Head change was unsuccessful, or else the problem is elsewhere.
Unfortunately I think is impossible to offer any further advice. If you still need data send to a professional.
PostPosted: November 5th, 2011, 1:02
its spinning but no head test
can you suggest any good DR in india
PostPosted: November 16th, 2011, 16:01
Hi
I am from India. you want I can help you. you can PM me.
DF :)
DF :)
www.datatracksystem.net
PostPosted: July 24th, 2012, 2:38
I have the exact same issue with a Seagate ST31500341AS. Did you manage to recover any data from your drive?
Thanks.
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 117 guests
