 Post subject: HTS543232L9SA00
PostPosted: November 9th, 2011, 11:11
Hi
I have this HD that goes ready when I plug it in to the Doctor, but when I try do load from HD, it goes on Error.
No clicks, or strange noises.
What to do? :roll: :roll:
I have this Donor fw: HitachiHTS543232L9A300
Will this be compatible?
ACELab partner
 Post subject: Re: HTS543232L9SA00
PostPosted: November 9th, 2011, 14:26
Hey :) Check PM
Data Recovery Cape Town
PostPosted: November 10th, 2011, 7:25
Did you get this one sorted?
PostPosted: November 10th, 2011, 12:24
Hi
I have a PCB and quoted the client. Waiting for approval. :wink:
ACELab partner
PostPosted: November 10th, 2011, 12:25
Good job :)
PostPosted: December 5th, 2011, 7:48
Back to this case...
What seems to be a NVRAM case, it's getting harder...
Tried to repair NVRAM, with no success. Tried hot swap with DDI, no success...
Does anyone have another suggestion?
Probably swap ROM?
ACELab partner
PostPosted: December 5th, 2011, 15:41
From what you told me in PM I think a replacement PCB is your answer. If the SD tools allow reading of patient NVRAM and writing of it to new PCB, then try that.
PostPosted: December 5th, 2011, 16:39
Probably swap ROM?
When you power on, can you hear the heads come off the ramp and seek?
PostPosted: December 6th, 2011, 6:45
Probably swap ROM?
Hi PCIMAGE
It spins up OK, but the heads doesn't seem to seek....
ACELab partner
Gonna try that now.
ACELab partner
PostPosted: December 6th, 2011, 7:19
Probably swap ROM?
Hi PCIMAGE
Possibly PCB, but my money is on preamp :-)
PostPosted: December 7th, 2011, 10:54
Problem solved :D
ACELab partner
PostPosted: December 7th, 2011, 10:59
pclab wrote:
Problem solved :D
Out of couriosity was it the pcb with nvram write or the preamp?
Loki
Users browsing this forum: No registered users and 303 guests
