 Post subject: ST3160812A - 7200.9
PostPosted: November 16th, 2011, 11:58
I'm using an Atola Insight and trying to image the drive. When I begin the drive spins up fine and identifies. after about 5 minutes of imaging it quits and then it fails to re-identify. Any ideas?
 Post subject: Re: ST3160812A - 7200.9
PostPosted: November 16th, 2011, 14:39
Heads, translator, simple bad sector....
PostPosted: November 16th, 2011, 16:13
Here is an update. After connecting to the terminal THis is all I get:
Interface task reset
4096k x 16 SDRAM
TONKA2 - 1_Disk M-31 03-22-06 10:53
Buzz - Head Mask FFFF - Switch to full int.
Spin Ready
(P)PATA Reset
DiskAccess ReadSector EC=43 at ffffffff.00.0002
Master
I know that usually Head Mask FFFF means head problems but I just want to make sure. It hangs at Master...
Thanks in advance
PostPosted: November 16th, 2011, 16:50
You have a firmware problem then.
PostPosted: November 16th, 2011, 18:54
I am curious, what does the Insight diagnostic show?
PostPosted: November 17th, 2011, 13:26
Insight Diagnostics show it is the firmware. All the tests complete successfully until the firmware test.
That is when it IDs. After it runs for about 5 min it doesn't ID again until it sits for about 30 min.
PostPosted: November 18th, 2011, 2:07
I told you so... :(
Users browsing this forum: Google [Bot] and 165 guests
