 Post subject: File recovery using custom file signature
PostPosted: November 18th, 2011, 12:56
I am trying to recover 2 types of files for a recovery job. One is an old Quattro Pro file with an extension of .qpw and the other is a Flash file with an extension of .fla (not .flv).
I found some documentation for the .fla file and created the following for use with PhotoRec:
extension offset header signature
fla 0 0xD0CF11E0A1B11AE100000000000000000000000000000000
This is my first time using a PhotoRec custom signature, so the above may not be the correct format.
I have not had any luck with finding documentation on the .qpw file. The most I have found is related to a different file type associated with Quattro.
Does anyone here know the correct signatures to use for recovering these 2 file types? I have researched this quite a bit, but have found very little.
 Post subject: Re: File recovery using custom file signature
PostPosted: November 19th, 2011, 6:02
I suggest to use Winhex / Easy recovery instead. You can add customer signatures easily.
PostPosted: November 19th, 2011, 7:20
as TaskManager said winhex
u can 1st. chk ur working files for file signature and those you wanted are well known u should not have any problem finding it if not exists on winhex then scan using the pre-defined extensions u wanted
good luck
PostPosted: November 20th, 2011, 3:04
I may have the original software. I know I have the original manuals. Would that help?
PostPosted: November 20th, 2011, 9:53
I recommend you to try R-Studio. The article Creating a Custom Known File Type for R-Studio explains how to find a correct file signature, and its help Customizing File Types explains how to add it to R-Studio.
Users browsing this forum: Google [Bot] and 111 guests
