 Post subject: Barracuda 7200.10 problem, S.O.L.? [ ST3750640AS ]
PostPosted: November 20th, 2011, 23:00
First time poster, long time forum browser. Questions, friendly comments, suggestions, tips, hints, etc. are welcomed
Please help! The problem is that I have forgotten a password to an old usb Maxtor OneTouch 4 Plus, and would like to regain access to the data on the hdd. I have made several attempts to try to remember the DrivePass password with no success.
The hdd is labeled as a Seagate Barracuda 7200.10 with firmware of 3.AFM, and is completely functional to the best of my knowledge. This disk drive was originally part of a usb Maxtor portable device. A password was set, forgotten, and the drive sat unused for a while. When removed from the Maxtor encasing, and connected to a Windows PC, Microsoft Disk Management does not recognize the hdd. The drive shows up and is recognized by HDDScan, SeaTools, and Microsoft Device Manager as ST3750640AS.
SeaTools log shows:
SMART: Supported and enabled
48-bit Address feature set supported: True
Max LBA: 1465149167
Host Protected Area features: Supported and enabled
Mandatory Power Management: Supported and enabled
Security Mode: Supported and enabled
SET MAX security extension: Supported not enabled
Advanced Power Management: Not Supported
Download Firmware: False
SMART self-test supported: True
SMART error logging supported: True
Drive Temperature(C/F): 30/86
Power-On Hours: 0
TestDisk 6.11.3 log reports a bunch of read errors.
HDDScan Identity Report lists:
Model: ST3750640AS
Firmware: 3.AFM
Serial:
LBA: 1465149168
Host Protected Area (HPA): Supported
Write cache: Enabled
Password Protection: Enabled
SMART: Enabled
Device Configuration Overlay (DCO): Supported
General Purpose Logging (GPL): Supported
along with a bunch of other things, I have only listed a few to help shorten the post a bit
The hdd can still be connected as a portable usb hdd, is properly recognized by the Maxtor software, and still asks for the DrivePass password when plugged in. After about 4 tries, the hdd locks until powered down, and then turned back on. To unlock the hdd, the software recommends using its DriveErase feature. After speaking with Seagate Tech Support; this feature "erases the drive, but does not format the drive" and by formatting the drive without using DriveErase, there was no information that specifically stated the password would be removed from the drive. So, all data remains on the drive, I have not 'DriveErased' nor formatted the drive and still cannot access my data.
With all of that said, what could be the best option to regain access (besides to remember the original password, lol) to this hdd?
:oops: & :( , thanks
 Post subject: Re: Barracuda 7200.10 problem, S.O.L.? [ ST3750640AS ]
PostPosted: November 21st, 2011, 0:12
read the post - SEAGATE: Non Standard ATA Master Password
PostPosted: November 22nd, 2011, 3:12
Thank you for the fast reply.
Kamen wrote:
If I understand correctly, this software would be able to unlock the ATA Password if it had been set. Would this be able to be used without losing data ?
Is an ATA password of the hdd == Maxtor's DrivePass password?
PostPosted: November 23rd, 2011, 3:54
If you are referring to SeDiv, it won't unlock your drive. The demo version will allow you to see your USER and MASTER passwords on the vendor track. You will then need to enter your user password using an application such as Victoria for Windows.
Users browsing this forum: Bing [Bot] and 275 guests
