 Post subject: CA - 42 NOKIA
PostPosted: November 20th, 2011, 5:15
please
advice me where to buy NOKIA ca-42 original cable with driver,
( in manchester UK
for work on seagate 1tb,
thanks
 Post subject: Re: CA - 42 NOKIA
PostPosted: November 20th, 2011, 5:22
Poundland
To be honest if you can't find one or make a suitable adapter on your own you havn't got a hope in hell of doing any successful terminal work on your 1tb drive!
PostPosted: November 21st, 2011, 5:30
Use google search for 'USB to ttl'
PostPosted: November 21st, 2011, 8:21
Also a good source is the MAX3232 and its datasheet. Not USB, but serial port
PostPosted: November 21st, 2011, 8:57
Why not do a search on Ebay & select a uk seller?
http://www.ebay.co.uk/sch/i.html?_from= ... Categories
http://www.ebay.co.uk/itm/Nokia-USB-Dat ... 27a9d1cb92
Or you could buy this from Drivestar in china
http://www.drivestar.biz/pc-usb-terminal-p-304.html
PostPosted: November 23rd, 2011, 7:36
I found using a usb to tll worked alot better then ca-42 cable.
http://www.ebay.co.uk/itm/USB-2-0-TTL-U ... 43a9f5b24a
is what I used and had better results then the ca-42 cable.
Users browsing this forum: Google [Bot] and 80 guests
