 Post subject: if a PCB board swap is sucessfull what do you do next?
PostPosted: November 22nd, 2011, 10:16
if your lucky enough for a PCB swap to work and you can access your data what do you do next before the hard drive fails again. Should I just copy everything or use a recovery program?
thanks.
 Post subject: Re: if a PCB board swap is sucessfull what do you do next?
PostPosted: November 22nd, 2011, 10:26
2 ways you can go:
1: Copy off the important data first
2: Image the drive
PostPosted: November 22nd, 2011, 10:27
okay thank you very much.
What is a good imaging program?
PostPosted: November 22nd, 2011, 10:29
IMHO : always choose to image the drive (or important part the the drive) with good tool/software and then recover files
Lemmy
PostPosted: November 22nd, 2011, 10:30
A program that can handle bad sectors such as dd_rescue if you're looking for something free.
Lemmy
PostPosted: November 22nd, 2011, 12:21
Wasnt sure if this was even a real question.... :lol:
PostPosted: November 22nd, 2011, 16:38
if its a case of DIY, I would save your critical files first. You may try to image and it fail at 60%, you might not have the data you need.
PostPosted: November 22nd, 2011, 18:06
Depends on how many are those "critical" files. If it is a case with a 500GB drive and client wants to recover a lot of 300GB of video files, then i'd image the disk. If they only want an sql database which is usually a few GB, i would just copy these somewhere safe and then image the rest.
Users browsing this forum: Google [Bot] and 223 guests
