Post new topic Reply to topic  [ 31 posts ]  Go to page Previous  1, 2
 Post subject: Re: ST9320325AS - 320GB SATA 5400.6
PostPosted: September 21st, 2011, 10:31
I am thinking this is either heads (most probably IMHO) or some problem with motor. But i think heads.
PostPosted: September 21st, 2011, 10:35
most probably heads (and surface)...
PostPosted: September 21st, 2011, 10:36
Edit: oops, sorry for double posting
PostPosted: November 24th, 2011, 0:00
Zebong - did you ever figure out the problem with your drive on this one. I have a ST9250315AS which is giving the same Terminal output.
Pesky
PostPosted: November 26th, 2011, 9:39
Heads problem > 80%, I had some similar cases with the same sympton.
PostPosted: November 26th, 2011, 13:16
It's heads or platter damage. Latter occurs quite frequently on this model.
PostPosted: November 29th, 2011, 22:41
I have the same problem. while I tried to work with PCB only, and got the same error. Does it mean something wrong with ROM?
PostPosted: January 8th, 2012, 10:56
cater99
Post subject: Re: ST9320325AS - 320GB SATA 5400.6Posted: November 30th, 2011, 10:41
yes,is rom wrong, try Change rom
PostPosted: January 9th, 2012, 8:53
This problem is related to heads on most of the cases.
Besides that, head swap does not work on a lot of cases, because there are different head types for this drives, so you must know which head type your drive and donor have.
PostPosted: January 10th, 2012, 1:16
Yes, indeed. dmarques is right. Most cases involved head replacement, but very tricky :mrgreen:
PostPosted: October 25th, 2016, 18:32
I've got a case with this same RW Err = 84150180 today. I'm assuming it's bad heads/preamp, but if there's something else I should know please do tell.
einstein9 wrote:
PM Sent,....
Can I get in on this PM?
Users browsing this forum: No registered users and 158 guests
