 Post subject: MFM Miniscribe HDD does not spin, how to repair??
PostPosted: December 7th, 2011, 14:12
I am trying to get my 20MB Miniscribe 3.5" hard drive running again.
The problem is that it doesn't spin up anymore when I power it up. I
disassembled the drive's PCB, and swapped it with the PCB from a
working drive, and the other HD works with both PCBs, so proving the
problem is with the spindle motor itself.
Looking closer at it, I notice that when I power it up, the platter
spins about 1/4 of a revolution, then stops forever, until I power off
and on again. Rotating it manually doesn't fix it.
What could be the problem? I feel that if I can get the HDD to
correctly spin again, I should be able to access the data. This drive
is vintage, so I'm doing all efforts to rescue it.
Thanks for any information, any hint, or any similar situation
experienced.
Luc
 Post subject: Re: MFM Miniscribe HDD does not spin, how to repair??
PostPosted: December 7th, 2011, 15:58
The problem is elsewhere. Do you still want to DIY or need professional help ?
PostPosted: December 7th, 2011, 17:14
I'd like to DIY and do all I can to rescue this drive... By the same occasion, I would learn more.
PostPosted: December 7th, 2011, 21:12
Could we see some pictures?
Did you measure the motor resistances?
Is there a tach sensor?
PostPosted: December 8th, 2011, 10:48
Good luck then... Take care as they are 'different' from actual 8).
PostPosted: December 8th, 2011, 10:55
what's the Miniscribe model number Miniscribe 8425 ?
PostPosted: December 8th, 2011, 18:03
Nostalgic mode on:
Oh, a nice old drive with a stepper motor. Those were the times..
(No, not talking about the spindle motor)
Nostalgic mode off
PostPosted: December 9th, 2011, 3:41
/nostalgia_mood =ON
Must be one of those nice puppies.... ah the ol'good times... ENTER BFI... play with head skew.... MFM vs. RLL.... :mrgreen:
/nostalgia_mood=OFF
Anyway, I still have many here (working!) where more or less the "platform" is the same...
PostPosted: December 11th, 2011, 4:44
Here is a small video of the motor behaviour. Only the PS and motor connectors are connected. Connecting the rest doesn't change anything.
Uploading it here doesn't work, so I'm putting it on YouTube.
Just search for "rpmcanada1971" "MFM" "Miniscribe"
Thanks for any hints.
PostPosted: December 11th, 2011, 4:51
Why??? Can't you just link to it?
PostPosted: December 12th, 2011, 17:41
O.K. Here is the link to my video.
Sorry, I'm more used to keyboard typing than mouse clicking.
http://www.youtube.com/watch?
feature=player_detailpage&v=0pbRAp0dR3Y
If it doesn't work as is, please paste it into your browser.
Louis-Luc
Users browsing this forum: Google [Bot], pepe and 63 guests
