 Post subject: PC-3000s Wanted
PostPosted: December 8th, 2011, 6:59
We're looking for several PC-3000s, UDMA with data extractor. Full version only please, not portable.
If you have any please reply with details of quantity, age, current update version and any other relevant details.
To pre-empt the inevitable posts about it being 'illegal' to sell these - ACE Labs have no problem with private sale, but they won't support them once transferred to a new owner so it imposes a shorter useful life on the device as they become out-of-date and this is reflected in their second-hand value.
 Post subject: Re: PC-3000s Wanted
PostPosted: December 8th, 2011, 9:21
I hardly-think some one will sale Pc3000 UDMA but it is worth to try.............
PostPosted: December 8th, 2011, 10:51
You didn't see this post further down the list then?!
3000-for-windows-udma-with-data-extractor-udma-for-sale-t19905.html
PostPosted: December 8th, 2011, 17:11
why don't you just buy a new one? You might have more luck then learning how to use it.
PostPosted: December 9th, 2011, 3:03
Thanks for the tip HDD Spaz, we already have a couple that we bought new.
PostPosted: December 24th, 2011, 6:17
Merry Christmas to all.
Still looking to purchase these if anyone has one or more for sale?
PostPosted: December 24th, 2011, 13:13
why you dont buy directly??
PostPosted: December 29th, 2011, 5:23
Cost and lead time. We already bought direct, and given the current financial climate figured there may be some used ones up for grabs. We're not using these for data recovery so we don't need the full support and update package the new ones come with.
PostPosted: December 29th, 2011, 9:50
Just out of curiosity and if you don't mind me asking, what are you using PC3K for if not for data recovery?
PostPosted: December 29th, 2011, 15:03
Drive refurbishing is about the only thing I can figure, am I correct?
PostPosted: December 30th, 2011, 7:56
or Cloning Maybe best guess is your comment.
PostPosted: December 30th, 2011, 8:09
The PC3K provides us with a test report that's filed with each drive, which is then wiped and sold to the DR industry for parts through our partner. They'll be posting a list once they've all been tested an catalogued, there are several hundred to get through so it'll take some time.
We have a couple that we bought direct for DR use, but these are working flat out - just looking to pick up some cheaper used ones for testing.
Can anyone have any thoughts on whether the PC3K Portable would do for this purpose? Our thoughts are if we get the full version we can use it for DR if needed, I suspect we'd regret buying the Portable due to missing features.
I've seen posts on here asking what is lacking on the Portable but no definitive answers, can anyone enlighten?
PostPosted: December 30th, 2011, 15:13
http://www.pc-3000portable.com/pc3000portable.php
Functionality PC-3000+DE (UDMA) PC-3000 Portable
Earlier HDD models support + –
Rare HDD models support + –
New HDD models support + +
Advanced engineering modes available + –
HDD autorecovery mode – +
Script system + –
ATA commander + –
Full-function DE + –
Limited DE functions* – +
Working with storage devices connected to system + –
Software Protection System Activation Activation
Activation key works for: one personal computer 2 personal computers
Software HDD power control + +
HDD resources database + +
HDD reference system + +
Software updates 3-4 times per a year 1-2 times per a year
_________
* – Limited DE functions does not have functions dealing with complicated logical analysis of file systems. Only Quick disk analysis, Partition analysis, Raw Recovery modes are available there. Building map mode functions are reduced: building files map method and building map for marked files method is not available. But PC-3000 Portable and PC-3000 UDMA formats remained compatible which allows to use PC-3000 Portable as the second working place for long reading of problem hard disk drives.
PostPosted: January 6th, 2012, 2:21
What functionality do you need?
PostPosted: January 9th, 2012, 13:18
If I read correctky, mabe something here would be better suited for application:
http://www.jharddrive.com/products/hard ... epair.html.
