 Post subject: Seagate Momentus 5400.2 diagnosis
PostPosted: December 11th, 2011, 7:14
I have a seagate Momentus 5400.2 disk which is having trouble initializing.
When HDD is powered:
1. Disk spins up
2. Moves head
3. Parks head
4. Spins down
This all happens in 2 a 3 seconds and is repeated until I power it off.
I connected to the terminal interface and the following repeating pattern occurs:
Head Mask FFFF - FInterface task reset
4096k x 16 buffer detected
MERCURY - 1_Disk 3.06 01-19-05 14:20
[...etc]
I am expecting something following "Head Mask FFFF - F...", But it appears to reset after that.
Anyone ideas about what could be the issue here or how I can proceed?
 Post subject: Re: Seagate Momentus 5400.2 diagnosis
PostPosted: December 11th, 2011, 9:51
Heads issue and possible platter damage.
Stop powering on and seek professional service for an accurate evaluation.
PostPosted: December 12th, 2011, 16:44
Is your opinion based on the symptoms, or the output from the terminal?
PostPosted: December 12th, 2011, 17:20
Terminal log looks like it would if power were being repeatedly interrupted. Check your wiring and PCB.
PostPosted: December 13th, 2011, 3:40
Yes looks like some problem with power. Cables, pcb, connections...
PostPosted: December 13th, 2011, 7:49
drc and northwind have valid points. I may have jumped the gun a bit, hence I suggested for you to get an accurate evaluation from pro.
Users browsing this forum: No registered users and 164 guests
