 Post subject: MK8025GAS Read SA but cant read Data
PostPosted: December 13th, 2011, 13:48
Not sure on this one,
Dropped, heads replaced. Comes ready with little effort.
Trying to read with no joy on UDMA or DDI.
any ideas, Just backed up SA no problem but getting it to read is a different matter :(
anyone?
ta
andy
Databusters Data Recovery Glasgow
http://www.datarecovery.co.uk/latest-data-recovery-jobs/
 Post subject: Re: MK8025GAS Read SA but cant read Data
PostPosted: December 13th, 2011, 17:14
What happens when you try to access sectors?
PostPosted: December 13th, 2011, 17:31
All timeout on DDI , can't get anything out it.
Yellow reds blacks on 3k and hangs. Goes no where.
Gonna try new heads I think
thanks
Andy
PostPosted: December 14th, 2011, 4:28
maybe motor is failing or g list problem.
PostPosted: December 14th, 2011, 4:55
to be sure, put back heads to donor and see if they work. If they do, then it is either head incompatibility with patient or some other problem as HDD Spaz says.
PostPosted: December 14th, 2011, 5:12
Thanks chaps
PostPosted: December 14th, 2011, 10:33
Often Glist needs to be cleared. Also sometimes sectors need multiple read retries to read. Alternatively, it could be an issue with the media or compatibility.
(I see many Toshiba and also Fujitsu 2.5" where surface is bad but heads are good, not sure why)
PostPosted: December 14th, 2011, 10:39
glist and smart cleared, gonna f - about with it see if i can get it to read .
thanks
Users browsing this forum: ccc, Google [Bot], pepe and 52 guests
