 Post subject: Acer Locked Hdd
PostPosted: December 14th, 2011, 14:14
Hello, I have an Acer Aspire 7736z forgot my hdd password (its locked). This is the infor for my hard drive: WD Scorpin Blue, 320GB (WD3200BEVT - 22ZCTO), dated 8 Jan 2010, Hdd Error Code is 09311, Disabled Code is 23130, any help would be greatly appreciated. Thank you!
 Post subject: Re: Acer Locked Hdd
PostPosted: December 14th, 2011, 15:17
With the right tools is easy....
Not sure if you have them...
ACELab partner
PostPosted: December 14th, 2011, 16:22
The 5-digit "disabled code" needs to be input into Acer's proprietary password unlocking software. You'll probably find his software on the Internet.
PostPosted: December 15th, 2011, 7:23
AFF Repair Station supports all WD 2.5" & 3.5" drives.
http://hdd-tools.com/products/rrs/
But it will cost you $49.95 but your data will be safe.
If you dont mind wiping your data then HDD Unlock is cheaper http://www.hddunlock.com/
will cost you $24.95 or $29.95
Loki
PostPosted: December 15th, 2011, 13:02
OK had some of these in here under PC laptop repair. How did you set the password? Did you do this one inside the BIOS so when you boot up your system the password is there on initial boot up? Or did you actually use the utility to set your password. Have you even taken this out of the machine and tried to see it on another computer? The ones that give problems here are ACER and AOpen to unlock this one. They do not accept the 5 digit codes. Depending on how you did this is how you can unlock this one.
Iorana Haraharaini
PostPosted: December 20th, 2011, 2:13
I think that should have been "Hdd Error Code", not disabled code, but I'm not abslutely certain.
Users browsing this forum: Google [Bot] and 338 guests
