Post new topic Reply to topic  [ 898 posts ]  Go to page Previous  1 ... 14, 15, 16, 17, 18, 19, 20 ... 45  Next
 Post subject: Re: Unlocking ATA Password for Western Digital
PostPosted: November 25th, 2011, 9:01
help me????
PostPosted: November 26th, 2011, 9:49
help me???
PostPosted: November 26th, 2011, 10:22
sanlima wrote:
ho provato la user wdcwdcwdcwdcwdcwdcw niente da fare
mi aiutate comunque leggendo i post precedenti , vorrei trovare la password e non mi interessano i dati che sono caricati
la passw è stata impostata forse da mio nipote ad un EEpc 1001 PX ASUS
If that is what you used then it is wrong!
The master password would at least be WDCWDCWDCWDCWDCWDCWDCWDCWDCWDCW as written.
And I would say the user password also looks rather strange.
You might have to retrace your steps and check your method. Something dosn't look right!
PostPosted: November 26th, 2011, 18:23
AIUI, the user password precedes the master password, in which case it is filled with zeros. However, the leading bytes are 01 01 rather than 01 07, as in other hex dumps.
PostPosted: November 27th, 2011, 9:18
as duties proceed from the two files in the figure 22.bin master password and user what would be??
I used MHDD and found the 22.bin then tried to use the software victoria 4:46 but I get error "Passport drives get error" why??
I wish I could help me just to learn one more thing
PostPosted: November 28th, 2011, 10:37
I want to help prop is not !!!!! is not it?
PostPosted: November 28th, 2011, 16:02
For Victoria for Windows you might have to set the bios into ide/compatibility or legacy mode.
You might also find the computer bios freezes the password function on boot. So you would have to plug in the power connection to the hard drive after the system has booted. With great care of course!
PostPosted: November 29th, 2011, 15:22
victoria victoria has no hard drive
PostPosted: December 4th, 2011, 12:43
allora????
nessumo mi rende felice in una operazione ben riuscita??
PostPosted: December 4th, 2011, 14:44
sanlima wrote:
allora????
:shock:
PostPosted: December 10th, 2011, 11:41
you are not the only one who can unlock a hard drive wd ...
I repeat that I have just unlucky
Meeting a master password and user are not a thief or other .....
help me :roll: :roll: :roll: :roll:
PostPosted: December 13th, 2011, 18:26
Hi guys...
I have Netbook Asus Eee with WDC WD1600BEVT - 22A23T0. I've tried to unlock it "M0RBI0US"'s way using MHDD, but my netbook doesn't have CD-ROM (I've already created bootable USB with Windows XP instead of CD), but I'm supposed to remove all drives except locked one. So then it says "Missing operating system".
Is there any option, how to fix it?
Thx
PostPosted: December 14th, 2011, 4:49
Yes. Put drive to a desktop machine and try the procedure.
PostPosted: December 14th, 2011, 19:27
hi all
I have a locked WD800UE , but the bin file looks different from the other ones in this thread.
It's an old 2.5 ATA 80GB drive which was used in a WD Passport enclosure but I was trying to put it in an old Acer laptop from which the Seagate drive was locked after upgrading the BIOS firmware.
But now the WD drive is locked as well :(
Any ideas ?
PostPosted: December 14th, 2011, 20:46
That's module 1Eh. You need module 02h.
Which script did you use?
BTW, you can see the structure of each module here:
http://www.datadonor.net/HD%20Western%2 ... 22HCT0.zip
PostPosted: December 14th, 2011, 20:48
Your drive does not appear to have a user password, only a default master password.
PostPosted: December 16th, 2011, 21:07
Hello!
Please help me, where is password ?
Uploaded with ImageShack.us
PostPosted: December 17th, 2011, 8:45
fzabkar - Thank's but password is bad :(
PostPosted: December 17th, 2011, 15:25
How did you answer the password challenge? Which software did you use?
PostPosted: December 18th, 2011, 5:42
My PM is blocked :(
I use MHDD, the master password and user password, but does not work.
DISPWD and password.
Users browsing this forum: No registered users and 80 guests
