 Post subject: WD1200BB-00GUC0
PostPosted: December 19th, 2011, 13:26
My father's disc (as above) has become completely unresponsive, not spinning up (tried in several machines).
I've taken off the PCB and could see what looked like visible over-heating damage to what I believe is the motor chip.
Image here http://flic.kr/p/aXKF5F on my flickr account.
I suspect a decent bet would be to swap the PCB on an identical disc, but I read that firmware may also differ even with the same model.
Can you advise what bit I should be looking for to try to get as close a match as possible - do I need to look in more detail than the 00GUC0 part of the model name, and where would I find it? Is it likely that any 00GUC0 version of the disc will have the same firmware, or at the very least have the same PCB from which I could lift the firmware? Could I cast my net more widely and get, say, a 00GUA0 model (which seem to be fairly freely available for about £20)?
Thanks in advance for any help you can give!
Matt
 Post subject: Re: WD1200BB-00GUC0
PostPosted: December 19th, 2011, 14:46
Find a matching board with the number 2060-701266-001 ( I am pretty sure that is the right board) and swap the small 8-pin chip label U12 over to the donor board and hope it works.
If you are not comfortable swapping the chip , find a local tech shop that will do it for you.
PostPosted: December 19th, 2011, 18:46
OK thanks, that's what I thought. Does anyone know of a good supplier in the UK?
Matt
PostPosted: January 5th, 2012, 18:11
Just thought I'd wrap this one up in case anyone else comes searching.
Just a few days after I'd bought a PCB from Dariius which was titled WD1200BB-00GUC0 I spotted on ebay a whole disk with that same reference.
When Darius' PCB arrived it had a different reference on the board than was on my actual drive so I waited until the whole drive arrived.
When that did, I removed the PCB from the dead drive and the ebay drive, and swapped over. I noticed that although the PCB boards were the same reference, one (my old one) used a samsung chip and the new one (from ebay) had a hynix chip. My old disk was malaysian manufactured, the ebay one was Taiwanese.
Swapped over the PCBs, plugged the drive into a USB caddy and the disk fired up straight away. No need to swap over the U15 chip or anything clever like that.
So I matched a WD1200BB-00GUC0 with a PCB from the same referenced drive, and it worked straight away.
Hope this helps someone!
Matt
PostPosted: January 5th, 2012, 18:39
Glad it worked, you got lucky with matching firmwares.
Back it up now
PostPosted: January 5th, 2012, 22:23
Those are SDRAMs. These chips need not be the same -- they only need to have the same capacity (or maybe not in all cases ?).
You could use my database to compare them:
http://www.users.on.net/~fzabkar/HDD/HDD_RAM.html
Users browsing this forum: No registered users and 174 guests
