Forum rules
 Post subject: Could use some help with Seagate Barracuda 7200.10 PATA/IDE
PostPosted: December 14th, 2011, 12:38
It seems that I am not able to send commands to the diag console. Hitting "." or ":" should get some feedback from the device, but nothing happens. My RS-232/TTL is working, double checked with 2 SATA devices.
This is all I get after powering on the hdd, so receiving works:
Reset
4096k x 16 DRAM
NHAWK - 1_Disk    S-42   03-27-07_13:01
Buzz HM SFI
(P)PATA Reset
Master
(S)PATA Reset
Master
pins I use:
|   PWR   | . T . G | ....
| ° ° ° ° | . R . G | ....
T - TX
R - RX
G - GND
I jumpered G to get the device configured as Master and also use at as GND. Every help is appreciated.
 Post subject: Re: Could use some help with Seagate Barracuda 7200.10 PATA/
PostPosted: December 14th, 2011, 13:08
Try "Ctrl-Z" first to get a "T>" prompt
PostPosted: December 15th, 2011, 17:23
This was the first thing I tried. Any other ideas?
PostPosted: December 16th, 2011, 4:53
Edited: Tada! :)
PostPosted: December 16th, 2011, 4:58
The code you display means that terminal communicates with your drive. If hitting CTRL+Z does not get you a prompt then maybe something gone bad internally. I think preamp controlls this signals. Does the drive click?
PostPosted: December 16th, 2011, 6:17
I did not notice any clicks and the problem applies to 2 drives. The above one and another with also stops interacting with me after I received
Reset
4096k x 16 DRAM
GALAXY - 1_Disk    S-6D   09-22-06_15:48
HM SFI
(P)PATA Reset
Master
(S)PATA Reset
Master
I have tested both scanned both drives with MHDD, and everything looks fine to me.
PostPosted: December 16th, 2011, 8:32
Oho, I just got an idea what I did wrong, if it is true... I'll hammer my head against my table so hard, that there will be no morning... :roll:
PostPosted: January 11th, 2012, 14:48
Well, at least you think you found out what was wrong. Please, let us know here, if possible. I am facing something very similar. I connect to the drive (hyperterminal, COM3) but I don't seem to have a prompt to edit any info. When I leave the connection, I have the option to save...
I am just researching the field and I never saw anyone doing any procedure. I am following some manuals and experimenting.
What I think my problem is in my case is I don't have a modem connected to my motherboard (and so who or what's going to translate the data I type?).
I may be wrong but, eh, that's how I can sleep at night.
Users browsing this forum: Bing [Bot] and 103 guests
