Post new topic Reply to topic  [ 22 posts ]  Go to page Previous  1, 2
 Post subject: Re: hdd wd1600aajs-22dsao spindle motor not moving
PostPosted: January 17th, 2012, 17:01
Vulcan wrote:
Also, I wouldn't bet that those tools will work with the existing PCB in its current state (seeing the OP's reluctance to get a replacement PCB), but that is only my guess.
Those tools are able to retrieve the relevant MODs from the SA in "low speed" mode, using a non-native PCB. These MODs are then used to regenerate the ROM image, after which the image is flashed to the PCB.
Fix Identification Problem caused by Corruption of ATA Overlay module or ROM content (ROYL):
http://www.salvationdata.com/blog/fix-i ... m-content/
Case Study on WD ROYL Drive Using WD Utility (regenerating ROM data)
http://www.salvationdata.com/blog/data- ... y-tools02/
PostPosted: January 17th, 2012, 17:41
Yes, I've read the claims :)
My point (which I obviously failed to communicate clearly in my previous post, so I'll try again :) ) is that the OP has chosen not to get a replacement (i.e. non-native) PCB, despite several recommendations to do so!
Without that, and using only a previously suspect (and now faulty) original PCB, I wouldn't bet that the software you mentioned will "do this job" (as you put it) with only that original PCB and its unknown fault(s). See what I mean?
Of course there would be more options, if only the OP had taken the earlier advice (first mentioned by poehere) to get another (working) PCB... :)
Users browsing this forum: Google [Bot], gps31 and 65 guests
