 Post subject: A bit of help with WD2500AAJS
PostPosted: January 27th, 2012, 16:33
Guys i come accross a strange hdd, its WD that have a lot bad sectors and results in I/O errors. Does anyone have a suggestion how can i skip this sectors and use the good ones instead? I'm perfectly aware that this drive cannot be saved with software i just want to try and use it for insensitive data (as caching) for as long as i can.
This is the SMART report:
ID   Attribute Description   Threshold   Value   Worst   Data   Status
01   Raw Read Error Rate   51   198   198   37847   OK: Value is normal
03   Spinup Time   21   194   178   1291   OK: Value is normal
04   Start/Stop Count   0   100   100   185   OK: Always passes
05   Reallocated Sector Count   140   104   104   761   Pre-Failure: Imminent loss of data is being predicted
07   Seek Error Rate   0   193   190   305   OK: Always passes
09   Power-On Time Count   0   80   80   14887   OK: Always passes
0A   Spinup Retry Count   0   100   100   0   OK: Always passes
0B   Calibration Retry Count   0   100   100   0   OK: Always passes
0C   Power Cycle Count   0   97   97   3864   OK: Always passes
C0   Power-Off Retract Count   0   197   197   2741   OK: Always passes
C1   Load/Unload Cycle Count   0   199   199   3864   OK: Always passes
C2   Temperature   0   107   87   36   OK: Always passes
C4   Reallocation Event Count   0   1   1   232   OK: Always passes
C5   Current Pending Sector Count   0   200   197   0   OK: Always passes
C6   Offline Uncorrectable Sector Count   0   200   200   40   OK: Always passes
C7   Ultra ATA CRC Error Rate   0   200   200   134   OK: Always passes
C8   Write Error Rate   0   200   200   33   OK: Always passes
 Post subject: Re: A bit of help with WD2500AAJS
PostPosted: January 27th, 2012, 17:21
Try MHDD to do this one with. But as you say you are not going to get so far on this one and it is not such a great idea to use it if this is the problem.
Iorana Haraharaini
PostPosted: January 27th, 2012, 18:50
Mhdd won't help that much, you need your drive to be professionally fixed. If successful, it will be like brand new.
PostPosted: January 27th, 2012, 18:53
Drive is dying, but could be recertified and reusable. But not without specialist tools I'm afraid :-(
PostPosted: January 27th, 2012, 21:37
What are these tools? PC3k? Or just high-price software?
PostPosted: January 28th, 2012, 18:12
AIUI, if the drive needs to be opened, then the job wouldn't be worth doing. Instead I would expect that it would all be done from behind a keyboard. I would think that a bad head or surface would simply be disabled, and the drive recertified at a reduced capacity.
If that's the case, then there are cheap software tools that could probably do the job, eg WD HD Pro (US$80 - $100) or WDR-UDMA (US$150).
PostPosted: January 30th, 2012, 13:13
This does not mean to open the HDD. Professionally fixed = refurbished. It is done by the SA and special commands to refurbish a HDD. Normally a refurbish process on a HDD is rather cheap. I can not quote you an exact price but I know it normally is under 30 euro on this one I think. Do not take my quote as your final price. Send BlackST a PM and ask him how much it would be to do this for you. He can give you the price on this and I have read on here sometime as low as 10 to 30 euro.
Iorana Haraharaini
Users browsing this forum: Google [Bot] and 230 guests
