 Post subject: SEAGATE NAS110 data recovery???
PostPosted: February 7th, 2012, 15:00
I have a Seagate Nas110 which somehow stopped connecting to my network. In a rush to get my data, I pulled the hard drive from the enclosure and directly connected it to my computer. Unfortunatley the drive was a GBT (?) Protected Partion or something like that. I thought that if I switched it over to a regular disk (unprotected it) I would be able to access my data... FAIL. Computer Management in Windows said I need to format it in order to read the drive when I assign a drive letter. Well I don't want to do that, I want to retrieve my data and throw this damn Seagate drive away. So I now have a hard drive with a few partions on it. Has about 4 at 97 megabytes and 1 at 9.38 gigabyte. My data is on the big partion. I tried using "Recover My Files" and it did find some files, however after I purchased the software and ran it again, it wouldn't find anything. The drive also keeps disconnecting as I monitor it in Computer Management and run "Recover My Files", so I am unable to retreive my data. I hear no funny noises from the drive so I don't think its crashing, but something is definitely not right. Anyone have any ideas how I can recover my data. I plan to go to a professional if that is what it boils down to.
Thanks in advance for any tips or help,
Nick
 Post subject: Re: SEAGATE NAS110 data recovery???
PostPosted: February 7th, 2012, 15:31
This should still be a fairly simple project with a pro who has all the necessary tools and knowledge to deal with these issues.
PostPosted: February 7th, 2012, 15:40
So you are saying just send the drive out to professional and quit messing with it myself?
PostPosted: February 7th, 2012, 15:50
Your only DIY chance is a cloning tool (eg ddrescue) that knows how to work around bad sectors. It clones the easy sectors on the first pass, and tries for the more difficult ones on subsequent passes.
PostPosted: February 8th, 2012, 7:02
Probably windows cannot read the file system.
Recovery my files will recover for you data based on signatures, i.e all files will have no names and original folder structure lost.
If you modify partition in computer management is possible you damage filesystem start making it more difficult.
If you do not know what you are doing a professional is the best option for you. If you do want to proceed then it could be worth looking into the file system you have, maybe get a screenshot of the disk in a HEX editor and post here.
PostPosted: February 8th, 2012, 9:40
Is this a BlackArmor? I am working on one which is password protected/encrypted. That could be part of your problem.
Data Recovery Cape Town
PostPosted: February 9th, 2012, 5:29
Which one is it? 220, 400 Series?
PostPosted: February 9th, 2012, 5:45
Not sure, will check. It's completed, just needed some pc3k tweaks and some time on the DDI in the end.
PostPosted: February 10th, 2012, 9:53
:wink: i have BOTH models
PostPosted: February 10th, 2012, 10:15
How you getting on with your new 12Tb 440 am thinking of the same from ebuyer from your previous recommendations.
Loki
PostPosted: February 11th, 2012, 3:46
my 12TB is 400, i got it empty w/o drives (cheaper if you look) and added my own 3tb x 4
BlackArmour is the Best NAS, and i mean the 400 here
2gigabit eth. Fast & Stable
btw, it comes if you wanna buy it with Seagate i changed it to WD drives
Users browsing this forum: No registered users and 85 guests
