 Post subject: 2TB WD Ext Hard Drive: From Lag to unrecognizable
PostPosted: February 10th, 2012, 16:44
I've had my 2TB WD external hard drive for about 6 months now with no problems whatsoever, until now. I had to take my laptop apart to fix the keyboard, which entailed me taking out the disk drive. So I got everything back together, it seems the disk drive is resetting or whatever, but my WD drive is lagging like crazy. When this first started the drive showed up and I could access and watch the video I have in the first set of folders, but when I went to the subfolders it just lagged and became unresponsive. I figured that it just had to go through and recognize the files and so I left it overnight. Today I checked it out and I could again access the video and it would go to the first subfolder but when I tried to access another subfolder it again became unresponsive. Then after unplugging it and restarting a few times my laptop wouldn't recognize the drive. It did say there was something there but not the usual MyBook:K that usually comes up. So I did some googling and went into disk management. The drive showed up on there, but when I tried to change the drive letter it said that it wasn't there and to refresh. I went to refresh, but with the drive plugged in, it took forever so I finally unplugged it and BAM refreshed (this goes for everything I try, if it is taking a long time and I unplug the drive it instantly comes up before closing). I also tried out my 500GB drive and that works just fine. So can anyone help me here? The drive was fine before I fixed the keyboard, but now it seems to be degenerating or something.
 Post subject: Re: 2TB WD Ext Hard Drive: From Lag to unrecognizable
PostPosted: February 12th, 2012, 20:30
It seems like your drive has a lot of read errors, therefore have to find exact problem in order to fix it.
Most likely you will have to recover data, replace your drive and move on.
www.datarecoveryne.com
Users browsing this forum: pclab and 68 guests
