 Post subject: Formatting Memory Card
PostPosted: February 10th, 2012, 19:56
Can some one help me in formatting my 2 GB Memory Card. I tried your Low Level Format utility 4.25. It formatted my MC successfully but the data was not erased and still I can see 1.54 GB of data present in my MC. Kindly help me.
TA
 Post subject: Re: Formatting Memory Card
PostPosted: February 10th, 2012, 19:59
Why are you trying to use any utility to format your card - what is the original problem?
What exact type of memory card is this?
Where have you been using it - PC or camera or ... ?
If this is a new memory card, where did you buy it?
(Just FYI, I've asked for this thread to be moved to the Flash Memory part of the forum - you've started this thread in a part of the forum for Hard Disks. Therefore soon you'll find this thread has moved to that Flash Memory part of the forum.)
PostPosted: February 12th, 2012, 14:41
since you haven't said which card type, just going to guess this will work:
https://www.sdcard.org/downloads/formatter_3/
btw the low level format utility is not for "Formatting Memory Card"
