 Post subject: serial connect - seagate momentus 5400.3
PostPosted: February 15th, 2012, 18:14
hi, i have hdd seagate momentus 5400.3 ST9160821AS lock with ata password. I try unlock it. Connect rs232-ttl usb adapter. Run putty, connect, after push sata power supply connector. Wrote this:
Reset
4096k x 16 DRAM
VENUS - 1_Disk    M-37   12-01-06_14:56
Buzz HM SFI
(P)SATA Reset
(H)SATA Reset
after few second
SFI
according to the instructions i was press ctrl + z. I should be viewable "F3 T>" but nothing response:( I could not write any char to putty. After try next hyperterminal and SeDiv. What's wrong? Thanks
 Post subject: Re: serial connect - seagate momentus 5400.3
PostPosted: February 16th, 2012, 6:13
You should see F3 T> if it's a drive with F3 architecture, what is not the case, as that one is still barracuda series.
The drive seems to init fine.
What's the issue with it?
PostPosted: February 16th, 2012, 16:50
He needs to break pwd .
PostPosted: February 17th, 2012, 18:11
yes, need break pwd or disable password and format....
PostPosted: February 17th, 2012, 18:42
i removed pcb from hdd. When connect putty show:
Preamp ID 00 unsupported
>/2
F>Z
F>U
F>
Buzz
>/1
F>
i try this manual:
http://www.hddoctor.net/how-to-remove-s ... -password/
but sediv console response:
Level F
Level F
Level F - Exit!
Cert Code Load Error!
INVALID Cert Code!
Users browsing this forum: Google [Bot] and 218 guests
