 Post subject: How to format from terminal?
PostPosted: February 18th, 2012, 10:38
What command should I run in the Terminal to quickly erase all data (format disk)? Seagate 7200.12, 500Gb.
 Post subject: Re: How to format from terminal?
PostPosted: February 18th, 2012, 18:03
Hi go to "Sticky/important topics. Beginners please look here first!", check out fasterase.
PostPosted: February 19th, 2012, 4:46
Nothing said about commands in Terminal.
PostPosted: February 19th, 2012, 18:42
Unlikely anyone will give terminal command, that's why I gave you other option. Instructions in the link I refferd to will erase the dive quickly.
PostPosted: February 19th, 2012, 19:13
@SquaL,
FYI, unfortunately the OP did not explain that this is a repeat of a question asked in their previous thread. This is not a healthy 7200.12 disk:
seagate-7200-similar-but-not-t21992.html
... and is usually not recognised by the host, to allow normal utilities to be run. :(
PostPosted: February 19th, 2012, 19:15
Check this link in a post on this very forum may have what you want
seagate-terminal-commands-t6411.html
Users browsing this forum: Stritom and 138 guests
