 Post subject: Identifying ROM on Seagate Barracuda ES
PostPosted: February 21st, 2012, 11:45
Hi guys,
As you can see there is damage to the PCB and I am performing a PCB swap (Luckily this drive came from a server and had an identical pair)
I need some help identifying which chip contains the ROM and needs to be transplanted?
I figured it would either be in location A, B or C (But I could be completely wrong).
Many thanks,
DR
 Post subject: Re: Identifying ROM on Seagate Barracuda ES
PostPosted: February 21st, 2012, 11:56
A. Upper right.
PostPosted: February 21st, 2012, 16:41
Datasheets for HDD memory ICs including EEPROM, EPROM, flash:
http://www.users.on.net/~fzabkar/HDD/HD ... Flash.html
PostPosted: February 21st, 2012, 18:52
Most helpful answer.
unknown wrote:
A. Upper right.
Least helpful answer.
PostPosted: February 22nd, 2012, 5:17
unknown wrote:
A. Upper right.
Thank you very much.
Thanks for the link fzabkar, will come in useful next time.
PostPosted: February 22nd, 2012, 6:25
@ thatdellguy..
I cant help but be reminded of the saying:-
"Give a man a meal and he will feed himself for a day - Give him the right tools, and he'll feed himself for a lifetime"
I think Franc's answer was more beneficial - in the long term.
just my 2 cents....
Steve..
http://www.eadr.co.uk
PostPosted: February 22nd, 2012, 6:51
I stand by my post. Just pointing out the obvious that happens quite often.
PostPosted: February 22nd, 2012, 10:42
I was going to just say www.google.com but I guess that would have won the "least helpful answer" prize
PostPosted: February 22nd, 2012, 15:48
drc wrote:
I was going to just say http://www.google.com but I guess that would have won the "least helpful answer" prize
Sometimes do it yourself means just that.
With the details found on each ic and a simple search it would be easy to work out which is the rom device.
PostPosted: February 22nd, 2012, 16:07
If you were searching for a "ROM" device, you would be unlikely to find a "flash memory". ;-)
Users browsing this forum: No registered users and 231 guests
