 Post subject: Cannot access anymore my Seagate 2TB 32000542AS
PostPosted: February 25th, 2012, 20:06
Hi All,
I follow the forum for some time and read information about hard drive problems, but this time it's my turn to seek some help :(
I made a mistake to buy HDD Barracuda LP from Seagate, then after 9 months of use, the drive failed, really not much used, just for Data saving or decompressing.
I heard click regularly every 2-3 days coming from the computer, but I was unable to localize which hard drive make this noise (was of course the Seagate... :evil: ).
Then now the Seagate start spin, then make many click and spin down.
What the problem for you ?
I think even skilled and resolving often IT problems, I dont have equipment to manage and open my hard drive...
What the best solution and not too expensive :mrgreen: ?
Thanks in advance.
Alec
 Post subject: Re: Cannot access anymore my Seagate 2TB 32000542AS
PostPosted: February 25th, 2012, 22:13
Best solution /advice is to send to a pro for quote and possible recovery. The symptom indicates bad heads which is not a DIY recovery it would be best to not continue any DIY recovery attempts the more you operate the drive the less chance of recovery.
PostPosted: February 26th, 2012, 5:24
No DIY. If you can accept data loss, replace the drive. Otherwise, you have to spend quite some money on it - according to the given symptom.
PostPosted: February 27th, 2012, 1:55
Thanks for advice, unfortunatly I need to recover some important files.
After reading the forum I was thinking to send the HDD to Jon@Data Savers LLC.
It's a little far from Europe, result will be expensive shipping cost, worth it ?
Alec
PostPosted: February 27th, 2012, 8:09
If you don't want to ship overseas, albeit it's an excellent choice, you have a wide choice between us in EU.
But - regardless of choice - don't expect to spend 50 EUR neither 100 nor 200... (AND everything depends on the actual failure).
Good luck.
Users browsing this forum: No registered users and 52 guests
