Post new topic Reply to topic  [ 24 posts ]  Go to page Previous  1, 2
 Post subject: Re: Ready to recover data: WD1600JS Photo of damage
PostPosted: February 29th, 2012, 11:42
Something like this type is better http://www.ebay.co.uk/itm/872D-2IN1-SMD ... 4600f83061
PostPosted: February 29th, 2012, 12:28
@saggy,
saggy wrote:
http://www.clasohlson.co.uk/Product/Product.aspx?id=168541881
Thats what I have used in the past to remove surface mount components.
Vulcan - whats your opinion on this one?
There are a few reasons why, personally, I wouldn't allow one of those on my lab workbenches. :(
The unit mentioned by loki is one of the many Hakko clones made in Asia. I've seen good and bad Hakko clones - I don't know where that particular unit is on the quality scale. IMHO good clones can be part of a cheap (though not necessarily durable) SMT/SMD rework capability, if you don't expect too much. One problem is that you can't easily check the quality of a clone before buying - don't believe everything that is claimed in an advert, as I've seen some amazing lies in equipment adverts. :(
PostPosted: March 5th, 2012, 0:53
Neil1 wrote:
The transfer was a success and the drive spun up but the file system showed 32 GB in a raw file structure, PANIC I thought id damaged the drive or overwritten something . I powered it down to read up on the RAW file structure, after that the drive wouldn’t spin up when the jumpers were configured as slave and wasn’t recognised in disc management.
Did you perhaps install the jumpers at the wrong end of the jumper block?
Some WD drives have a PM2 jumper that configures the drive to Power Up In Standby (PUIS).
There are also Alternate Capacity jumper settings to account for BIOS capacity limitations. Perhaps that is why the drive identified itself with a reduced size of 32GB.
PostPosted: June 27th, 2015, 14:17
Thank you man...
i got same problem. My disk is wd1600js and i have wd2500js's board.
İnchallah i will recover my data..
baker450 wrote:
Success!
The U12 swap worked wonders, I was able to retrieve all my data from the WD1600JS. :D
During the desolder I was very careful, and basically used wick to remove solder, then heated the pad and lifted the leg with a pin. Not the best method, but these were all the tools I had to use. Soldering the chip onto the PCB I didn't find easy, but again I was careful and took my time so as not to heat up the chip too much.
After putting the modified PCB onto the WD1600JS, the first sign it was working was in the bios where it was recognised with the proper code, man what a relief it was seeing that bios screen. The drive seemed rock solid while copying files over.
I think I might try to put the original U12 chip back on the donor PCB, and use that HDD from now on. Or perhaps my newfound confidence is pushing the boundaries by doing this. I can't see any problem though, as long as my soldering job is good.
Can I say, a big thankyou to the gurus on this forum. By reading various threads outlining the procedures I was able to recover some important files from a HDD I would have otherwise thrown in the bin.
Users browsing this forum: No registered users and 31 guests
