 Post subject: Hitachi IDE 40GB Clicking
PostPosted: March 4th, 2012, 2:31
Hitachi IDE 40GB HTS421240H9AT00
Clicks non stop and then spins down.
Is this something I can do with Hyper Terminal or PC-3000? Or probably too complex and I should send it to a lab?
 Post subject: Re: Hitachi IDE 40GB Clicking
PostPosted: March 4th, 2012, 10:43
You can't do much to be honest.
Only thing you could do with it is to read nv-ram, to check if it's structure is ok, what I think it is, or else the drive probably would not spin.
So the problem might be related to heads or pre-amp. It's better to take it to a local lab for a quote.
PostPosted: March 4th, 2012, 10:59
Drive is pretty old so I would say Heads are gone.
www.datarecoveryne.com
PostPosted: March 4th, 2012, 11:37
WD 40GB I saw with same symptoms 2 weeks ago.
PostPosted: March 4th, 2012, 12:51
@networks Wow. Mess.
@OP I agree with others, it's bad heads.
