 Post subject: Seagate Barracuda 7200.10 PCB Repair/Replacement
PostPosted: March 5th, 2012, 14:55
I have a 400GB Seagate drive that I use as a backup drive. Long story short, I set it resting inside the case, and when I plugged it in, I shorted one of the components on the PCB board.
My questions are these:
1. Can the fried component be removed and the drive used anyway? (probably not, but worth a shot)
2. Can the fried component be replaced, if so, what exactly is it?
3. I believe the board can be replaced, with a board with the same processor & revision #. Is this correct?
3.5. If the above is correct will this replacement board do the trick? http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=160724089199
ANY input would be Greatly appreciated!
Thanks,
Marvin J
 Post subject: Re: Seagate Barracuda 7200.10 PCB Repair/Replacement
PostPosted: March 6th, 2012, 4:35
You need to find a board # 100406533 and swap over the rom chip.
PostPosted: March 6th, 2012, 5:16
... assuming something else is not fried :(
PostPosted: March 6th, 2012, 8:45
Ah yes, I forget this one these days.
"Assuming it is a pcb fault only, no other damage in drive and you understand and accept the risks of DIY".
If you mess this up, recovery can be impossible or very expensive. If you are not sure about what you're doing, consult a pro.
Otherwise, and if you understand risks etc, read my suggestion above.
PostPosted: March 6th, 2012, 21:03
Very unusual burn....
www.datarecoveryne.com
PostPosted: March 6th, 2012, 21:55
If necessary, some board suppliers include a "ROM" or "firmware" transfer for US$10:
http://www.onepcbsolution.com/seagate-b ... 20010.html
In your case there is an Atmel 25F512AN serial flash memory chip at the top right corner of the PCB.
That said, the "unusual burn" appears to be in the vicinity of the preamp connector and could be part of the preamp's negative supply. I can't tell for certain, but the burnt component may be a current or voltage sensing resistor, in which case one would have to be concerned for the survival of the preamp.
PostPosted: June 6th, 2012, 22:53
Are you still looking for this pcb board? We have it in stock.
Seagate, Maxtor, Western Digital, Samsung HDD PCB Supplier. Free Shipping.
Contact: sales@hddzone.com
Users browsing this forum: No registered users and 101 guests
