 Post subject: Toshiba MK8025GAS with motor problem - BlackST can you help
PostPosted: March 14th, 2012, 19:15
Hi all,
I have this drive with motor problem, here in Italy there are many companies that told they can repair it but how I can be sure?
BlackST please help me?
Thanks, Giuseppe
 Post subject: Re: Toshiba MK8025GAS with motor problem - BlackST can you h
PostPosted: March 14th, 2012, 22:30
What are the drive symptoms that make you believe it is a motor problem?
PostPosted: March 15th, 2012, 3:58
Tra poco lo sapremo...
We'll know soon ...
8)
PostPosted: March 15th, 2012, 6:14
For this puppies (Toshiba MK8025GAS) most probably.
Angel Data Recovery
PostPosted: March 15th, 2012, 9:45
With this models the noises are like cars motor. :D
PostPosted: March 15th, 2012, 10:26
... but they say on top cover :
RATTLE NOISE IS NORMAL
:D
PostPosted: March 15th, 2012, 10:40
lol =) 40 and 60 gig affected as well. Fun times. The first time i had a drive like that i almost head a heart attack shutting the power =) Sounded like someone threw a stones in a dryer =) Yet data came out 100 percent after the swap +)
PostPosted: March 15th, 2012, 19:44
Typically yes motor issues, but I was just asking in hope of the OP saying that he opened the drive or another somebody.
PostPosted: March 16th, 2012, 2:39
cibgiu wrote:
Hi all,
Thanks, Giuseppe
Motor is indeed common problem with this series, should be pretty straightforward for any half-decent pro. I'm sure there are a few in Italy on this forum that can handle this easily!
PostPosted: March 16th, 2012, 7:24
Just needs a little "cooking" :)
PostPosted: March 16th, 2012, 10:27
I already sent a PM, just waiting a reply... 8)
PostPosted: March 16th, 2012, 13:25
Can the OP even reply to PM with 1 post to his name?
PostPosted: March 18th, 2012, 11:11
Hi all,
sorry for the long delay...I've ADSL problem (tipically in Italian rural area :( )
I've searched the web and found many peoples with motor problem, I found a web page taht says "•when holding it next to the ear you might hear slight ticking or scratching noise as if motor tries to spin up but cannot" with a sound sample taht is like my problem (is a commercial page so I think the link cannot be posted).
I wonder if there is a low cost solution (not DIY) or for recover the drive is necessary a motor replacement?
Thanks, Giuseppe
PostPosted: March 18th, 2012, 11:14
Sure? How?
PostPosted: March 18th, 2012, 11:24
Sorry but I'm newbie and the system give me no permission to send PM: "We are sorry, but you are not authorised to use this feature. You may have just registered here and may need to participate more to be able to use this feature. "
I've NOT opened the drive
PostPosted: March 19th, 2012, 4:14
Need to see the drive . You have PM.
PostPosted: March 19th, 2012, 11:06
Hi BlackST
can you email me at mailcibgiu @ virgilio it
PostPosted: March 20th, 2012, 12:57
Hi hddguy
in this post mk8025gas-platter-swap-t9661.html#p58210 you told "These drives use fluid bearings which 'dry' up. You can use a hot air gun to heat the motor at the rear of the HDD being careful to protect the PCB" it's a possible solution?
Thanks, Giuseppe
Users browsing this forum: No registered users and 321 guests
