 Post subject: Toshiba MK325GSX changing PCB
PostPosted: March 22nd, 2012, 5:10
i have a Toshiba MK325GSX 320Gb with a dead pcb i have the donor drive. do i have to change the ROM chip? and if yes which one? i tried hot swap with DDI but shows me "I" when getting data.
thank you
DSC00597.rar [1.82 MiB]
Downloaded 357 times
 Post subject: Re: Toshiba MK325GSX changing PCB
PostPosted: March 22nd, 2012, 5:16
if you will change the full pcb ,yes you must swap the rom chip. but first try repair the pcb .see the fuses and coils after the power connector
Tawfeek Mokhtar
http://alsafwapc.net
Alsafwa Data Recovery Egypt
PostPosted: March 22nd, 2012, 5:31
i suppose the rom chip is the IC305
PostPosted: March 22nd, 2012, 13:04
athlesi7 wrote:
dead pcb i tried hot swap.
:shock:
PostPosted: March 22nd, 2012, 15:27
IC502
PostPosted: March 24th, 2012, 20:47
IC305 is part of a power supply. The adjacent coil provides the clue to its function.
See http://www.users.on.net/~fzabkar/HDD/HD ... Flash.html
... and http://www.users.on.net/~fzabkar/HDD/HD ... _Regs.html
PostPosted: March 26th, 2012, 2:21
Thank you all for your help
Users browsing this forum: No registered users and 260 guests
