 Post subject: old western digital hard-card: extracting the data
PostPosted: April 5th, 2012, 7:37
hello all
I've got a very old olivetti pc that i used when a student (from around 1990). I'd like to get the data of its hard-card but i'm struggling a little. Have extracted the hard-card from the (knackered) pc and powered it up externally. it spins fine but i don't have any appropriate connectors to get to the data.
the hard-disk itself has two ribbon cables to ide type connectors. one is 20 pin and one is 34.
is there a connector i can buy (i can't find one!) that will allow me to connect these to a usb port on my laptop to get the data off or am i needing to send this to an expert?
many thanks and best wishes
 Post subject: Re: old western digital hard-card: extracting the data
PostPosted: April 5th, 2012, 7:53
for clarity - i've added a couple of pics:
You need the attached controller or another ST506 MFM / RLL interface. They were XT 8 bit or ISA AT 16 bit cards. The PC likely is a M24 or Mxxx series.
PostPosted: April 5th, 2012, 7:58
Hardcards... that's a long time ago. Disk, controller, and host adapter on an ISA card. First versions being 10 and 20MB. Those were the days :D
Interfaces and protocols weren't much standardized back then. I reckon your best chance to get your data off the hardcard is to put it into an ISA slot in a PC running DOS. You will probably also need a DOS driver for the card to make it work.
PostPosted: April 5th, 2012, 8:10
indeed! a long long time ago....
this one's 32mb if i remember correctly. Sadly, the pc it came from is banjoed and is now on its way to the big crusher.
i really just want an image of this disk so i can create a virtual machine from it but would settle for being able to get at the data on it.
nothing particularly valuable just a load of memories of my time as a student :)
PostPosted: April 5th, 2012, 8:13
thanks BlackST - found a wikipedia page that explained your post and the function of the two cables (34 pin cable = head positioning and 20 pin cable = data).
so looking at it i actually need to be able to connect via the PCI slot... gah this is harder than i'd hoped!
send it off to a pro? any ideas?!
PostPosted: April 5th, 2012, 8:18
Almost all those controllers had external BIOS extension so all you needed was to set the disk type, on many Olivetti PCs you needed also a proprietary SW to setup CMOS :D .
Would be no problem to me to get data or even repair the HDD itself or the controller (still have them !)
Edit : haven't seen interfaces for old ST506 / ESDI that run on actual PCI slot AND in any case it would be a problem to make everything work on "MODERN" PCs - maybe they do exist but didn't see in real life. I always like the shorter and simpler way to do things...
PostPosted: April 5th, 2012, 8:30
thanks again - if you're able to take a further moment, i'd welcome a p/message with details of costs and timescales to get the data back. if it's possible to create a bootable iso from this disk (as it was the main boot disk running dos 5 if i remember).
ta
Ian C.
PostPosted: April 5th, 2012, 8:37
It's OK :)
Note : if it was a 286 or later series it may be possible that DOS version was 5 , if older maybe it was 3.xx up.
PostPosted: April 5th, 2012, 8:41
it was an 8086 thing, not a 286. but i'm pretty sure i had dos 5 on it.
no matter either way :)
PostPosted: April 5th, 2012, 16:55
I can't see all the gold fingers, but the controller looks like an 8-bit card. I have never tried to install an XT HDD controller in an AT-class machine, so I wouldn't know what to expect. In any case, you may find it easier to procure an AT-class machine (286, 386, 486) and a 16-bit RLL/MFM card. Then remove the HDD from the hardcard and plug the drive into your 16-bit controller. You would need to go into your BIOS setup and choose an appropriate CHS combination for your model.
If you end up with a 486 board that has an onboard IDE controller, then you will need to disable the IDE ports in the BIOS.
The whole exercise shouldn't cost you more than a McDonalds Happy Meal. :-)
In fact you may even be able to procure the hardware for free.
PostPosted: April 17th, 2012, 17:21
sorry for the delay - many thanks fzabkar; much appreciated.
Users browsing this forum: runner978 and 55 guests
