Post new topic Reply to topic  [ 31 posts ]  Go to page Previous  1, 2
 Post subject: Re: HDDScan - Issue
PostPosted: March 31st, 2012, 4:06
I know :@) it was a general observation after I read the whole topic :@)
Mine was to the point, too. :wink: :idea:
PostPosted: March 31st, 2012, 6:09
guru wrote:
Nice and to the point :)
Someone take a look at guru I think he's suffering with stiction. :mrgreen:
S
It's always somethin, and if it ain't somethin, it's somethin else - Cptn. Paul Watson.
PostPosted: March 31st, 2012, 6:46
PM Sent.... with details guys
PostPosted: March 31st, 2012, 14:18
Yep, my smartphone decided to keep posting.!!
S
PostPosted: April 1st, 2012, 7:33
For some reason i guess that all comments/replies makes sense here
i have 1 more last test to try (not related) hope solves my problem with those
Many thnx guys
PostPosted: April 1st, 2012, 8:35
Doomer wrote:
Here is the fields of ATA ID command buffer used by HDDScan
Word 21 - cache
pNode.Attributes['Name'] :='Cache size';
if IDEID.RETIRED_21<>0 then
pNode.Attributes['Value'] := IntToStr(IDEID.RETIRED_21 div 2)+' KB'
else pNode.Attributes['Value'] := 'Not Reported';
Word 168 - form factor
pNode := iNode.AddChild('Main');
pNode.Attributes['Name'] :='Nominal Form factor';
case (IDEID.DEVICE_FORM_FACTOR_168 and $F) of
0: pNode.Attributes['Value'] := 'Not Reported';
1: pNode.Attributes['Value'] := '5.25"';
2: pNode.Attributes['Value'] := '3.25"';
3: pNode.Attributes['Value'] := '2.5"';
4: pNode.Attributes['Value'] := '1.8"';
5: pNode.Attributes['Value'] := '<1.8"';
end;
Word 217 - RPM
pNode.Attributes['Name'] :='RPM';
case (IDEID.RPM_217) of
//0: pNode.Attributes['Value'] := 'Not Reported';
1: pNode.Attributes['Value'] := 'Solid State Media';
$401..$FFFF:pNode.Attributes['Value'] := IntToStr(IDEID.RPM_217);
end;
I want to get RPM for SSD drives :mrgreen:
Very nice Mr.Doomer.
PostPosted: April 1st, 2012, 15:59
As is already explained by Doomer's code, the ATA standard does distinguish between SSDs and HDDs. See Table 37 in section 7.16.7.77 of the following document:
Working Draft AT Attachment 8 - ATA/ATAPI Command Set (ATA8-ACS):
http://www.t13.org/documents/UploadedDo ... A8-ACS.pdf
Word 217 indicates the nominal media rotation rate of the device and is defined in table 37.
Value  Description
0001h  Non-rotating media (e.g., solid state device)
At the risk of being accused of spoonfeeding, here is a method by which an end user can determine the RPM of his drive:
http://groups.google.com/group/comp.sys ... 36d4afc140
PostPosted: April 2nd, 2012, 8:57
As is already explained by Doomer's code, the ATA standard does distinguish between SSDs and HDDs. See Table 37 in section 7.16.7.77 of the following document:Working Draft AT Attachment 8 - ATA/ATAPI Command Set (ATA8-ACS):http://www.t13.org/documents/UploadedDo ... A8-ACS.pdfCode:Word 217 indicates the nominal media rotation rate of the device and is defined in table 37.Value  Description0001h  Non-rotating media (e.g., solid state device)At the risk of being accused of spoonfeeding, here is a method by which an end user can determine the RPM of his drive:http://groups.google.com/group/comp.sys ... 36d4afc140
Hello Mr.Franc. Thanks for your input. But I am just joking. :)
PostPosted: April 2nd, 2012, 9:10
Well,
He did Not Notice the Mr Green Icon lol
PostPosted: April 4th, 2012, 4:46
@ All
i found the problem/solution after all and why its too damn slow
subject closed
and thnx for the replies/comments
PostPosted: April 9th, 2012, 12:28
Would be great to read how did you solved your problem einstein9 :wink:
Users browsing this forum: No registered users and 227 guests
