Post new topic Reply to topic  [ 898 posts ]  Go to page Previous  1 ... 18, 19, 20, 21, 22, 23, 24 ... 45  Next
 Post subject: Re: Unlocking ATA Password for Western Digital
PostPosted: March 3rd, 2012, 9:22
hello,
please help me find my master password
thx for help
NN
PostPosted: March 21st, 2012, 20:51
M0RBI0US wrote:
hi i was stuck with the same problem which i solve on a WDC2500bevt
just a quick list of master pwd i found on my travels
WDCWDCWDCWDCWDCWDCWDCWDCWDCWDCW <----THIS ONE WORKED FOR ME
WDCWDCWDCWDCWDCWDCWDCWDCWDCWDCWD
&'()*.WDCWDCWDCWDCWDCWDCWDCWDCWDCWDCWD
h2oinsyde <-----for acer drive(but not mine)
if none of the above work then the fun begins
first download MHDD boot disk (google for it)
copy the unzipped files i put up on to a usb stick and plug in
remove all drives except locked one
boot the cd and press F5 (safe mode)
type 'c:' to get to the contents of usb drive
then type MHDD to run the program on the usb not the cd as that is wrong version
in MHDD (select drive this might take a little bit of getting use to!)
run the script by typing ".dump" or ".dump2" (two different scripts)
the script will run and return "DONE"
read the 22.bin file if DUMP script run ok with a hex editor
and 42.bin if DUMP2 script run ok with a hex editor
also read all other posts for more info
hope this helps
and a great big thanks too all who posted and helped me save 8 months worth of HNC elec engineering work thanks!
Nirvanowiec, a big xtra thanx for the script i used....
MHDD.zip
So I'm trying to follow I've created a magic boot disk v2 and
unzipped everything you have on your MHDD.zip to the USB thumb drive and plugged it in
I remove all drives except locked one
I booted the cd and pressed F5 (safe mode)
I typed type 'c:' to get to the contents of usb drive
but it gives me invalid drive specification. I've tried all the drive letters as well.
PostPosted: March 24th, 2012, 13:31
I don't understand why anyone wants to be able to crack their own external drive. Sorry if you lose it but I don't want anyone to be able to crack the data on mine, WD, or the government. What is the purpose of encryption if it can be cracked. Either use it without the encryption or don't bother.
If it isn't secure I would use something else.
PostPosted: March 24th, 2012, 14:04
@Focal,
FYI, ATA passwords for WD disks (the subject of this thread) and on-disk encryption are totally different things. Setting an ATA password on its own, does not encrypt the data on the disk.
PostPosted: March 29th, 2012, 8:59
alright I am fed up trying to figure this out. I need someone to help me unlock this drive without losing my data, I will pay! message me with a price and location. Obviously you have to be within reasonable distance from NYC.
PostPosted: March 31st, 2012, 21:23
http://www.hddunlock.com/
PostPosted: March 31st, 2012, 22:14
ArdenEdition wrote:
OK HERE GOES !!!!
i will attempt to step by step talk you through how i unlocked MY OWN
1, Download This http://hddguru.com/download/software/mhdd/mhdd32ver4.6iso.zip
2, Burn The ISO to a CD
3, Then Download This http://forum.hddguru.com/download/file.php?id=1434
4, Put a USB stick into the Computer FORMAT it to FAT32 and copy the contents of Step 3, to the USB stick
5, REMOVE all drive appart from the DRIVE you wish to retreive the 22.bin or 42.bin FILE from
6, Pop the USB stick into the compter put the CD in the drive and BOOT FROM CD !!
7, when you boot from CD hold F5 and you will be on a Command prompt Screen
8, TYPE C:/MHDD.exe and let it run
9, Type .dump this will create your 22.bin file and save it to the USB stick
10, Put the drive with windows back in load up windows and open the 22.bin with a HEX editor
http://download.cnet.com/3001-2352_4-10891068.html?spi=1d0165043acacd9f99df7e625b92ca3c&idl=n
11, You should see a file like everybody is posting up here with WDC WD3200BEVT-22ZCT running down the side or something similar
12, POST your results up here and me and the rest of the lads will TRY cant PROMISE, but we will TRY help get your password
Arden
Great Directions been reading this forum for quite some time and for kicks decided to try and unlock a drive that i had someone else set a password on was a piece of cake with the directions and a bit of reading
PostPosted: April 1st, 2012, 6:02
Well ,
Remember i tell you sometimes you do not read ,he said without loosing data .your website will erase it
"While unlocking, HDD Unlock Wizard will erase and re-certify the drive.
If you need unlocking which is safe to your data, please use A-FF Repair Station"
So he has to use A-FF Repair station or find a Dr guy with the right tools
PostPosted: April 1st, 2012, 9:28
But A-FF cost money ! ;)
PostPosted: April 1st, 2012, 16:23
hwlcd wrote:
... I will pay! message me with a price and location. Obviously you have to be within reasonable distance from NYC.
A-FF is only as far away as your keyboard. :mrgreen:
PostPosted: April 9th, 2012, 13:30
I've been reading this thread for two days now, and I THINK I've followed the instructions. Not a complete n00b, not by a long shot, but I must say I am impressed by the knowledge and experience some of you folks have. I'm a self-taught geek, and I pride myself in being able to find the solutions I need. But yes, I do need a hand with this one. I hope I've given enough information here, including the 22.bin file snip. Thanks SO much for any help!!
Chris
PostPosted: April 9th, 2012, 13:42
I was going to send the .bin file itself but it desn't let me. Here's the dropbox link to it..:
http://dl.dropbox.com/u/4537616/22.BIN
PostPosted: April 9th, 2012, 15:26
Did you try the WDCWDCWDC.... WDCW password ?
PostPosted: April 9th, 2012, 16:08
Yes, and several derivations of it, ending in a W, a D, and a C.
PostPosted: April 10th, 2012, 13:18
Hello
I have a hard drive that has ata wd5000avvs password
Czytałem side of this topic, but I do not know English so well that I understood that.
I read in the password file, you can check 22.bin
Could someone explain step by step to me as I do and run this script?
MHDD on a bootable USB drive I already have.
How to make a script and turn it on - then search for the same hex.
Thank you and sorry for the duplication topic
translated by google translator
Plsss.... help :|
PostPosted: April 10th, 2012, 14:50
Hello again. New to this forum, and to hardware manipulation in general. I made a post yesterday with a .bin snip, and another with the .bin file itself. Overnight I received a PM from an apparent regular to this board, so I am taking that advice in this subsequent post.
The drive I'm trying to unlock does not belong to me. It is a co-worker's drive, who had been having some blue screen issues with his Vista installation. Instead of seeking help right away, he tried to fix it himself (I'm sure we've all been there..). In the process he was poking around in the BIOS of his Dell, and proceeded to password both the BIOS and the hard drive. He's not too concerned about the laptop, but he needs some data from the drive itself, namely his 2009 taxes. He said that if he cannot get this information, the IRS is going to try and nail him for $53,000 in back taxes.
That's the background. Now to the present. After realizing that the most likely and safest way to bypass the BIOS password would entail replacing the motherboard, I decided I'd take the drive out and connect it as an external to my desktop. A hundred hours of scanning with ZAR produced nothing. I then removed the HDD from my laptop, and set his in its place. It was then that I realized the HDD itself was passworded as well. After three tries it locks the drive out.. Does this prevent MHDD from seeing it correctly? That lead me to this forum and this thread. It would appear that all the information I need is somewhere in the first four pages or so, and I have tried like everything to follow the instructions, but something is still eluding me. Here again is the .bin snip. I hope I've given enough information, and any and all help is greatly appreciated.
Thanks!!!
Chris
PostPosted: April 11th, 2012, 2:34
So if your co-worker has password protected both bios and hdd, why won't he unlock them? Just connect the hdd back to the machine in question, enter BIOS and have him enter the passwords.
PostPosted: April 11th, 2012, 3:45
He says he's forgotten them. I grilled him today and he gave me a few to try, to no avail. Said he was drunk when he did it.
PostPosted: April 11th, 2012, 6:24
Well,
i Do Not Believe This even 1 Percent
PostPosted: April 11th, 2012, 7:10
http://www.youtube.com/watch?v=lZJ4vazuxYE :)
Users browsing this forum: No registered users and 45 guests
