 Post subject: Hitachi [ 3.5" SATA ] HDS721050CLA362 - Always Busy
PostPosted: April 11th, 2012, 5:01
Well,
No Idea How Many Of you have researched this drive family .Got one case And It Stays Busy .Had a spare Board Of the Same MCU But Not 100% Compatible " the Two Lines of the white sticker label on pcb Does not match " . I changed The Board Of The Patient With the Donor And Soldered The ROM From the Patient To donor .Same symptoms .
Any Help Guys you Can Give Me On This
 Post subject: Re: Hitachi [ 3.5" SATA ] HDS721050CLA362 - Always Busy
PostPosted: April 12th, 2012, 3:07
Amarbir wrote:
Well,
Sorry that i'm hijacking your thread and i'm really of no help here, but why are you writing the majority of your words in capital letters? It is really annoying.. and just plain hard to read :(
PostPosted: April 13th, 2012, 10:40
ipx wrote:
Amarbir wrote:
Well,
Well,
Its just a habit i just replied to you the way you liked lol
PostPosted: May 11th, 2012, 10:47
Guys ,
Can You People Assist a Little Here .Or shall i send the case back to customer please .
PostPosted: February 7th, 2014, 6:08
I have exactly a Same Model HDD with Alwasy BUSY status.
The HDD was received with dead PCB, replaced including NVRAM but it stays alwasy BUSY.
__________
THANK YOU
SHAHI
shahi.mahbub@gmail.com
PostPosted: February 7th, 2014, 8:24
Describe the drive's mechanical behaviour a little. Spin, no spin? Get any heads activity? If so, like what? Spin down afterwards or not? Etc.
PostPosted: February 8th, 2014, 1:01
Spinning OK, No abnormal sound. Spin down after a while
__________
THANK YOU
SHAHI
PostPosted: February 8th, 2014, 8:03
Sounds like firmware or heads.
Know the history of the drive? What did the owner say?
Is it from external?
PostPosted: February 10th, 2014, 2:11
According to customer explanation:
He hooked up the HDD to another computer for data transfer but didn't transfer data, then took back to original PC again and then he sees the HDD isn't working anymore. Later while I found the HDD was with PCB problem, replaced including NVRAM, but no detection. Spinning was normal, but AlWAYS BUSY. That's the history.
__________
THANK YOU
SHAHI
PostPosted: February 10th, 2014, 8:14
Mhh, not a lot that can point to anything specifically. If can't read any of the SA, then likely a heads issue.
PostPosted: February 10th, 2014, 9:12
As it is always BUSY, so there is no access to SA!
__________
THANK YOU
SHAHI
Users browsing this forum: rasz_pl and 81 guests
