Post new topic Reply to topic  [ 32 posts ]  Go to page Previous  1, 2
 Post subject: Re: Marvell PCB Alternatives
PostPosted: January 10th, 2012, 6:17
hddguy wrote:
positivebit wrote:
i have got 701615 (usb interface) possible replace with a SATA one (?)
You can use as example 701499, from Denali series.
I AGREE
Tawfeek Mokhtar
http://alsafwapc.net
Alsafwa Data Recovery Egypt
PostPosted: January 24th, 2012, 5:06
1622 PCB have been successfully replaced to 1590. 1537 PCB have been tested too, but upper heads doesn't work properly.
PostPosted: April 13th, 2012, 11:34
I have a 771754 (USB). What can it be replaced with (SATA)?
No need to recover the data inside the disk, just want a functional drive.
PostPosted: April 13th, 2012, 18:27
usb-sata-new-model-pcb-t22310.html
PostPosted: April 15th, 2012, 3:16
Should have searched for 771754 instead of 2060-771754-000. Sorry for that, and thanks for pointing me in the right direction.
PostPosted: June 10th, 2013, 2:35
tawfeek_mokhtar wrote:
701508 you can us 701494
Successfully tested. Thank you.
PostPosted: August 30th, 2014, 5:19
what about WD500BMVV-11GNWS0
PCB:
701675 (USB)
what is the similar SATA PCB?
PostPosted: August 30th, 2014, 5:38
Find a board with the same MCU and motor controller (88i9045-TFJ2 and SH6601AD):
viewtopic.php?t=22310&start=20
http://ep.yimg.com/ca/I/yhst-1443758497 ... 67_6088366
http://ep.yimg.com/ca/I/yhst-14437584971410_2271_857360
PostPosted: November 3rd, 2014, 16:32
If anyone needs it in the future, the 701675 ( in my case wd3200bmvv-11a1cs0 ) was compatible with 2060-771672-004 rev a from wd3200bevt-00a0rt0
ninja edit PS :
Ace lab DE ability to decrypt on the fly is AMAZING =) Swap heads on a USB native drive , convert to SATA or find a compatible board and hello Robert , my favorite uncle. =)
PostPosted: November 3rd, 2014, 21:24
deleted
PostPosted: November 4th, 2014, 11:20
Doomer wrote:
deleted
Damn. Now my OCD is flaring up and i cant stop thinking what was written here that warranted a deletion... =))
A terrible DR secret ? An incantation to repair damaged media ? THAC0 of the helium filled drives ? Obamas birth certificate ?
42?
PostPosted: September 8th, 2015, 3:42
thanks
also 701590 you can use 701477
Users browsing this forum: Majestic-12 [Bot] and 80 guests
