Post new topic Reply to topic  [ 29 posts ]  Go to page 1, 2  Next
 Post subject: Word file password question
PostPosted: April 23rd, 2012, 13:53
A friend called and said one of his clients used a password to lock a Microsoft Word file, and forgot it.
Does the password become part of an encryption key? Is there any solution without the known PW?
http://www.datasaversllc.com
 Post subject: Re: Word file password question
PostPosted: April 23rd, 2012, 14:32
What version of word is the file created in.
PostPosted: April 23rd, 2012, 15:06
You'll probably need Thunder Tables for a recent MS word file.
Data Recovery Ireland
PostPosted: April 23rd, 2012, 15:30
Disagree with you, will take no more than 2min. MAX.
PostPosted: April 23rd, 2012, 15:38
Care to elaborate? Unless there's something I don't know about that doesn't involve a rainbow table or brute force attack, then I don't agree with you but I stand to be corrected...
PostPosted: April 23rd, 2012, 15:48
http://www.petri.co.il/recover-word-2010-password.htm
Otherwise ask Google:
http://www.google.com/search?q=%22micro ... k+OR+crack
"About 1,930,000 results"
PostPosted: April 23rd, 2012, 15:49
Passware
PostPosted: April 23rd, 2012, 16:25
Passware might find it with a dictionary attack in 2 minutes but not if it's a complex password or above Office 2003.
PostPosted: April 23rd, 2012, 16:34
Thank you for your helpful replies.
I referred the client directly to Cleanroom, who contacted us with more info.
Jono
PostPosted: April 23rd, 2012, 17:18
Passware Kit Enterprise and Passware Kit Forensic utilize Amazon Elastic Compute Cloud (EC2) a highly scalable cloud computing platform for accelerated password recovery.
That should speed up the process.
Loki
PostPosted: April 23rd, 2012, 18:20
That was my point Loki, "regular" PW cracking is not sufficient. You need tables or GPU processing.
Anyway, that's all I have to say about the topic :wink:
PostPosted: April 23rd, 2012, 22:03
From what I know Office 2010 does 100000 SHA1 hashings (50000 for Office 2007) to the passphrase before using it as an encryption key in AES128 encryption
Even with Compute Cloud it will be very long brute force process
Unless you client is using very simple password
PostPosted: April 23rd, 2012, 22:09
http://blog.crackpassword.com/2009/07/o ... re-secure/
PostPosted: April 24th, 2012, 3:08
Most of the Office work regular people set simple passwords = easier cracking
if you look @ it from this point you will find the answer and it does work based on my experience.
Unless someone who want to play FBI and sets a complex one. :wink:
PostPosted: April 24th, 2012, 4:39
So, you are wrong then? Your original reply suggested that you would get the password in 2 minutes. This was based on the probability that the password was something easy like "password1"? What if the password was $"£%FSDJFXDJ$"-19e492()&*?? I hope you aren't charging $50 for password cracking :)
PostPosted: April 24th, 2012, 6:34
PostPosted: April 24th, 2012, 7:08
This is the reason people dont set simple passwords....
PostPosted: April 24th, 2012, 7:22
up till now, and more specific in Office docs. i never had any problem with it maybe lucky
but also consider regular people set easy password to remember not using pass. generators as the sample provided on prev. post
whatever is the case, i guess no need to go any more discussing this issue, will not lead anywhere right :wink:
PostPosted: April 24th, 2012, 8:37
How many percent is the "most"
And how short/easy are the "simple passwords"
I would like to see this statistics
PostPosted: April 24th, 2012, 8:43
I can set VjqK.mbvsqGfhjkm password and it will be almost impossible to crack but very easy for me to remember because it's Russian phrase typed on English keyboard
One can take a phrase from a movie and add some digits/symbols inside and dictionary attack will be very limited
Example: TheMatr1xHasUNeo
Users browsing this forum: Bing [Bot] and 262 guests
