 Post subject: Seagate Data Recovery Question
PostPosted: May 1st, 2012, 12:26
My hard drive on my laptop crashed.
The drive is a Seagate (ST9500420ASG Momentus 7200.4 SATA 3Gb/s 500-GB 9HV144-150)
Here is what happens...When I install it within a HD enclosure onto a Windows Vista machine, It will recongize it in Disk Management as Unallocated space. Once I initialize it (within Vista) it tells me that a I/O error occured. I could not read it all because it would not initialize. The next thing I did was put in a Windows 7 pc direct as a slave hard drive. The computer did not recongize it anywhere what so ever. Then I used the same HD enclosure and my PC did the same thing as it did in Windows Vista, However it did show up in Device manager. This time though when I went to initialize it in Windows 7, it gave me some sort of semaphore error which im not sure about.
Once the drive is powered and even though it did not initialize there is no banging or scratching noise which I believe means the head is broken. Throughout my research I found that if it gets recongized within Device manager but wont initialize, it could be the logic board which is the board above the casing of the platters. The reason I come to the forums to see if anyone can agree or give me advice about changing the logic board and If I order another drive that is exactly the same and just change the logic board (pcb) if it would work and initialize my drive so I can extract the data?
Any advice would be deeply appreciated!
Thanks!!
 Post subject: Re: Seagate Data Recovery Question
PostPosted: May 1st, 2012, 12:40
most probably bad sectors on the beginning seek a Pro. if ur data are valuable
Users browsing this forum: Bing [Bot], Google [Bot] and 70 guests
