 Post subject: Hitachi HTS545050B9SA00 Failure
PostPosted: May 6th, 2012, 11:28
Hello friends,
symptoms : spin up, make calibration, stays busy for 30 seconds and get DRDY, DRSC bur not recognized.
There's two strange sounds after calibration.
any thoughts/ideas ?
P.S :I don't have PC3K UDMA
Thanks in advance
 Post subject: Re: Hitachi HTS545050B9SA00 Failure
PostPosted: May 6th, 2012, 11:54
Had one last week with exactly the same symptom. 2 of the heads were dying, required headswap in my case.
Data Recovery Cape Town
PostPosted: May 6th, 2012, 12:09
Thanks for your reply Mr.Nick_CT,
I will try to search for a donor to perform a headswap (It's very difficult here in Egypt to find a donor for those hitachi's)
I appreciate your reply.
PostPosted: May 6th, 2012, 12:59
you may also try HM
PostPosted: May 7th, 2012, 9:26
After replacing 4heads the drive make the same thing.
The problem must be ELSEWHERE.
Any suggestions ?
PostPosted: May 7th, 2012, 10:27
Put the heads back into the donor, do they still work?
Maybe you have some media damage.
PostPosted: May 7th, 2012, 10:32
Hello Mr.Nick_CT,
I have moved the patient's heads to the donor and it working. So the problem not heads.
I believe now that the problem not head/s or preamp. It must be FW, but I don't have the proper tool to access the SA for those new hitachis.
PostPosted: May 7th, 2012, 13:05
einstein9 wrote:
you may also try HM
Users browsing this forum: Google [Bot], mecrazzy243 and 74 guests
