 Post subject: WD MY PASSPORT
PostPosted: May 7th, 2012, 5:08
I have a drive with - 2060-701675-004 (USB INTERFACE)
Is it interchangeable by 2060-701672-004 (SATA INTERFACE)?
__________
THANK YOU
SHAHI
shahi.mahbub@gmail.com
 Post subject: Re: WD MY PASSPORT
PostPosted: May 7th, 2012, 23:25
If the processor is the same (number on top line of big chip) then it should work AFAIK. IF rom, will need to move.
PostPosted: May 8th, 2012, 9:32
Check your PM.
www.datarecoveryne.com
PostPosted: November 8th, 2012, 12:26
Doesn't the motor controller have to be the same for it to work?
