 Post subject: Dell Mini PCI-E SSD [ How To Interface ]
PostPosted: May 8th, 2012, 10:39
Guys ,
Got a case today .Its a Mini SSD From a Mini Dell Lappie .I was Interested To Find Out If We Have a SATA/Pata/USB To Mini PCI-E Adapter For This for that we could use that and fire up our logical data recovery utils .In the Case i got the client tells me its locked .But i had no method to check the same as in my lab i had a lappie with mini pci-e slot but when i was inserting this into that the laptop would start automatically and there was no display .Read it on ebay that there is a Difference between mini pci-e and mini pci-e SSD .Can anyone point me to the right direction
Images Are Attached
 Post subject: Re: Dell Mini PCI-E SSD [ How To Interface ]
PostPosted: May 8th, 2012, 11:08
Isn't that just a standard sata interface?
Connect it to any motherboard with sata and power connector.
Just make sure the conectors are the right way round!
PostPosted: May 8th, 2012, 11:20
Hi
@ dick
That is not a standard sata connector it's just a mini pci-e connector which is internally converted to sata by the motherboard...
@Amarbir
Here you go:
http://www.amazon.com/Aleratec-MiniPCIe ... B005PYLKO6
Rgds
www.datasave.ro
PostPosted: May 8th, 2012, 11:29
ccc wrote:
Hi
@ dick
@Amarbir
Here you go:
Rgds
Sir ,
Before i Posted here i was on ebay and i have a link that i like to share
the link -> http://www.ebay.com/itm/Renice-mSATA-Mi ... 5649b49e1b
Here he mentions
" mSATA is Mini PCIE SATA SSD
mSATA is not mini PCIE SSD(used in ASUS netbook)
mSATA is not MSATA(MicroSATA)
whats he trying to say there ?
PostPosted: May 8th, 2012, 11:43
I stand corrected!
Somehow I completely confused it with my Micro sata interface which it is not!
PostPosted: May 9th, 2012, 1:14
Hi Amarbir
I think what he is trying to say is that the adapter is only compatible with those SSD's listed there....
Anyway, after more googling it looks that this is an PATA?? SSD not a SATA...Here is a link where you can find how to repair this SSD in case it shows 0 MB capacity....
http://www.mydellmini.com/forum/dell-mi ... -bios.html
But be AWARE that this operation is data destructive so, if you want the data ,does not apply in your case...
Rgds
www.datasave.ro
PostPosted: May 12th, 2012, 10:26
In what notebook model was this mini SSD mounted? If you can write motherboard part number/model.
Users browsing this forum: jcan and 24 guests
