 Post subject: WD10TPVT-00U4RT1
PostPosted: May 8th, 2012, 23:10
After Connecting the HDD - STATUS comes READY.
While LOAD FROM HDD - Everything loads fine Except HEAD COUNT (it shows - 6) Under Low Speed Access But Status "ERROR"
Then FW Defect Scan (It's ACCESSIBLE) - Stops after scanning few F/W - Then Scan Again, in repeat - It completes without any DEFETCS. All r FINE.
Made a SMART RESET.
In Defects List Management - VIEW DEFECTS LIST - doesn't come with First try, in 2nd try Shows Everything...
Translator Regeneration was also made.
The drive has SLOW ACCESS - in every 900000 to 1000000 sectors it starts to see BAD(ERRORS)
Checked different area randomly, it's happening where ever I tested.
Is it happening due to Poor HEAD?
__________
THANK YOU
SHAHI
shahi.mahbub@gmail.com
 Post subject: Re: WD10TPVT-00U4RT1
PostPosted: May 9th, 2012, 20:54
Original raw SMART values?
PostPosted: May 10th, 2012, 4:00
Didn't keep the original SMART value. But it was FINE.
__________
THANK YOU
SHAHI
Users browsing this forum: Google [Bot] and 120 guests
